Everything posted by Sylvi
Fuel Tank Leak
Mr. Sumith, I have done more than 50 Petrol and Diesel tanks bottom welding. What I do is remove the tank empty all fuel on same then allow to dry up one day under hot sun before welding examine the tank has no fuel in. The tank has to be filled full of water close the filling side turn up to do the welding remove the drain plug. Clean nicely the corroded part weld with brass the leaking area or use a new patch of 20 SWG Iron sheet on top of the tank corroded area and do a brass welding around. Wijesinghe.
Silencer & Fuel Economy
Mr. Prasa, I topped up the fuel tank full and added one bottle I think it is 150 ML Any petrol station will have I paid 450.00 Rs. for STP. Wijesinghe.
Abandoned Cars ?
Sir, I apologize if you think I Advertised that car at Deal place. I WROTE SAME FOR INFORMATION OF MEMBERS. THANKS FOR POINTING OUT THAT FOR MY POST. Wijesinghe.
Abandoned Cars ?
Master Don, CI Goon... Ex M/s, Walker sons Agents for Austin Cars If I remember was our Caption of Srilanka Cricket teem in 1960 He was married to one Miss Fernando she passed away last year they have one son in UK. Will check how many cars he has now. Mr. ######## Weerasinghe has one American car still not completed. One Muslim Gentlemen Mr. Madi at Deal place Kollupitiya has another American car in very bad condition (corroded body) originally owned by his farther he wants to sell same but no figure wants us to quote. if any one is interested can give his contact number. I have seen lot of Austin 30 1950/1960 model cars rotting around Colombo. Wijesinghe.
Abandoned Cars ?
Members, Mr. CI Goonasekara at Dickmons road had some old Cars. Wijesinghe.
Intermittent Power Failure To The Audio Setup - Nissan Sunny N16
Sir, I have had this problem on my Ken wood Radio set and that has a CD player too. Check your charging voltage it should be under 14 Volts DC maximum can go up to 14.5 DC Volts Some Sets has built in cut off power as safety above specified Voltage. Others I cannot comment as I did not have any problems you have mentioned. Wijesinghe.
Sir, I tried STP injector cleaner in my vehicle it is very good and gave me good results. As I have lot of other things added to my Engine to get more Kms for a liter I get 2kms in Colombo and 4to6 Kms out of Colombo. Depending on driving out of Colombo if I drive on 5th gear I get more KMs for a Liter. Colombo I cannot use 5th Gear. Wijesinghe.
What I Found About Maintaining Batteries
Mr.Nishan, THIS I GOT FROM THE WEB. Check your batteries on a regular basis to be sure they are getting charged. Use a hydrometer to check the specific gravity of your lead acid batteries. If batteries are cycled very deeply and then recharged quickly, the specific gravity reading will be lower than it should because the electrolyte at the top of the battery may not have mixed with the "charged" electrolyte. Check the electrolyte level in wet-cell batteries at least four times a year and top each cell off with distilled water. Do not add water to discharged batteries. Electrolyte is absorbed when batteries are very discharged. If you add water at this time, and then recharge the battery, electrolyte will overflow and make a mess. Keep the tops of your batteries clean and check that cables are tight. Do not tighten or remove cables while charging or discharging. Any spark around batteries can cause a hydrogen explosion inside, and ruin one of the cells, and you. There number of articles on web and get more information. ******************************************************************************** ******************* My experience with Battery and Alternator charging system. I check my battery water level every 45 days Voltage every month it is 14.5 Volts when engine is running with lights and other full load on DC. Bottled Battery distilled water is added if the level is low. I never use Acid. Hydrometer reading is S/G is around 1230 to 1250. I have fitted Amp meter it shows during day running +3 Amps as you start it goes to about 40 Amps within 60 to 120 seconds Amps comes down to said amount. In the night with lights on Amps shows +5 Amps. I don't use a battery more than 18 months. Before it fails I change to a new battery. Wijesinghe
Where Can I Buy Powered Jack And Wrench
- Where Can I Buy Powered Jack And Wrench
Sir, What you are looking for battery powered Electric Impact Wrench, hydraulic jack. Rechargeable Impact wrench I have one which I bought from USA never used same I am not selling that. You may be able to get a battery powered Impact wrench battery or rechargeable of same. But battery powered hydraulic Jack I don't think will be available here in Srilanka Can fabricate one from a Japanese truck rear door closer lifter that can lift about three tons. It will be little bit heavy as it comes with hydraulic tank with oil and hose pipes for the Jack most of them are 24 Volts DC. Try with A.C.Pa*ul, General Equ##pment, My T**ls. I have seen what you want in Developed country's in automated work shops to handle work fast. Wijesinghe.- Micro Junior 111 Van
Dear Mr. Dilku, Telecom may use any thing for their workers to travel I think they first Used Buddy Vans. I do not want to condemn that van which is assembled in Srilanka as one post says seats are not comfortable For my knowledge users give lot of negative answers for last few years. Lot of new small vans are coming to the market used and new in another 30 to 45 days. It is better to any one to be patient till they come some are Japanese and Chinese petrol and Diesel At the moment Chinese small van has arrived like D*MO batta with more powered engine 4 cylinder same cost. Wijesinghe.- Micro Junior 111 Van
Sir, I too wanted to buy one of this type of van 3 years ago and had a demonstration also but the space is very small like a buddy van. and I was informed by a worker in that work shop known to me for more than ten years lot of negative points of same. But I see number of them running on the road Assembled by the micro cars Ltd. Get a users experience of their service and go for a new one. Wijesighe.- What Does Unregistered Mean?
Sir, I will check up and give you the correct amount. Or call 1919 and get their help to a customs officer will give you all details. I will be out of Colombo today if you cant find out send a message to the Forum. I will get all information and give you on next working day. Wijesinghe- What Does Unregistered Mean?
Brand new Vehicles will be charged according to normal tax structure. Reconditioned Vehicles have A depreciation Value according to Agents value. Only cars can import 3 1/2 years old.- What Does Unregistered Mean?
Sir, During the time of Registration the new owner will have to pay only RMV Registration fee Insurance charges Luxury Tax Number Plate charges Annual license fee. Luxury tax comes if the Vehicle is in that Category ( Depending Engine CC Capacity). Wijesinghe.- What Does Unregistered Mean?
Sir, I my self is a importer you cannot clear a vehicle out of harbor without paying all levy's. If this vehicle is not registered in some body's name in Srilanka RMV then it is called unregistered. When A Vehicle comes to harbor it can be on Letter of Credit or cost With a wire transfer. After that we have to give all documents to Customs authorities will appraise the Vehicle after settling the full levy's the Vehicle comes out of the harbor. this Vehicle is called unregistered. Wijesinghe.- Auto Lanka Need A Major Revamp
Dear member, If you want any changes come out point out directly what is good and bad your suggestion to correct any mistakes. What is the best way to revamp Auto lanka. To help motorists in Srilanka in their Automobile problems. As well as the motor traffic law is concerned.As any motorist will notice Traffic Police is working to their whims and fancy's Then moderators will take care of your suggestions. Wijesinghe.- Defender Brake Issues
Sir, Can you send a picture of your Brake Master cylinder pump or give the model of your L/R Chassis number I will try to get you the new cost of same from a dealer of Land Rover spares as I live in Colombo 00300 go at least once to spares dealers for a day. Wijesinghe- Is This The Only One In World?
Original Engine compartment with 6 Volts Dynamo. http://images.thesamba.com/vw/classifieds/pix/3275633.jpg- Is This The Only One In World?
OK Restoration is fine but if I am not mistaken this model had 6 Volts system now I find 12 Volts Alternator on that new engine. If it is so not restored to original specifications. In 1970 middle Original 12 volts VW Vans and cars came with a 12 Volt Dynamo. Friend of mine restored a 2 Sri VW Parts from Brazil cost him more than 2M Rs with original 6 Volts system. Srilanka at that time agent for VW did not have any spares for that model. Wijesinghe.- Import Tax Slashed By 50%
Sir, Very well said Mr. Pericles Your comment is most welcome you had mentioned and reminded for the second time above said to all forum members. Wijesinghe.- Using Maintenance Free Batteries
Sir, Investing on a cheap voltmeter and a trickle charger too is good insurance in my experience... You are perfectly correct in the Battery trickle charger comment over night charging will extend battery life. I have had trickle charger experience for thirty years back when we had Diesel Peugeot cars which was a frailer in Srilanka due to difficult starting in the morning most of my friends who had those vehicles I fixed trickle chargers for their cars. All these chargers were assembled by me with a Transformer and a full wave rectifier to give 2 Amps DC. Wijesinghe.- Is It Safe To Get Rid Of The Thermostat Value Completely?
Mr. Sumith, Did you buy this NISSAN Genuine thermostat Valve from the agents or from a one of their dealers. You get inferior quality valves made in other country's printed as genuine parts with the dealers. Get your money back and try with Agents. Wijesinghe.- Battery For The 4dr5 Jeep
Mr. Nisdhan, I apologize delay in reply did you sort out your Battery problem. Wijesinghe.- Plz Help Me To Find I Need To Find The Interior Dome Light Door Switches
Sir, Did you get the door switches? Wijesinghe. - Where Can I Buy Powered Jack And Wrench
