From where can I buy Powered Jack and Wrench (powered by vehicle's power) in Colombo? Is there a preferred brand?. Looking these for a Toyota Vitz
Sir,
What you are looking for battery powered Electric Impact Wrench, hydraulic jack.
Rechargeable Impact wrench I have one which I bought from USA never used same I am not selling that.
You may be able to get a battery powered Impact wrench battery or rechargeable of same.
But battery powered hydraulic Jack I don't think will be available here in Srilanka
Can fabricate one from a Japanese truck rear door closer lifter that can lift about three tons.
It will be little bit heavy as it comes with hydraulic tank with oil and hose pipes for the Jack most of them are 24 Volts DC.
Try with A.C.Pa*ul, General Equ##pment, My T**ls.
I have seen what you want in Developed country's in automated work shops to handle work fast.
Wijesinghe.
Hi there, I have a feeling that your 12v battery won't be able to power an impact wrench etc. But I'll take a look for you next time I head into a store to see whether its available...
Edited by Kavvz
Well, both products were available but none of the major brands had any offerings. The fact that its available in the retail market overseas probably means you could find them in Colombo (or failing that on Ebay) . However I can't warranty for the effectiveness of these products as I haven't used them myself.
Product descriptions are as below:
Impact wrench
Car lifter / jack
Edited by Kavvz
Sir,
I thank you for your post about the jack I picked up an idea regarding the Electric Motor operated Jack.
I have seen electric Hydraulic Jack with remote control Hydraulic pump works on solenoid principle.
I can suggest this can be fabricated easily in Srilanka to a normal scissor Jack.
Dc 12 volts smallest serviceable stater motor available in old spare part shop which will cost around Rs 3000.00.
Fabricating with two motor cycle chain driven wheels with out a remote control have to fix a switch to rotate clock and anti clock.
I will definitely fabricate one and inform to the forum of the cost.
Wijesinghe.
What's vehical your having....
If your going for a electrical winch It would be roughly 60k 12v if your using 24v system... u need to get a correct converter & convert it to 12v..If not u have to keep changing side your battery once a month.
High lift jack you can get for 8k... bt nt hydrolic..............
@3000cc - Hi, the vehicle is Toyota Vitz (2007). so i think there is no need to get a converter. do you know a place that sell those items?
  • 1 month later...
