Newest Vehicle Colour change Process at RMV
Wow, Such a painful process. However, it's good that they do a proper roadworthy. They should make it a requirement for registration transfers as well. This way, buyers have a better chance of getting a mechanically sound vehicle (given that the seller does the roadworthy before transfer forms are obtained).
Stucked manual transmission
It's a car that's almost 50 years old. It could be pretty much anything since you don't know the history of the car. I think the first mistake was driving a car that had only 2 gear left in it. You should have either towed it or put it on a flatbed and taken it to a garage. As Twin Turbo suggested, you should take off the oil drain bolt of the transmission to see if there's oil in it. If not, driving the car without oil in the transmission probably caused it to (fully) seize. You'd have to take the transmission apart and see if it can be rebuilt. If there is oil, and the oil is good, check to verify if the linkages between the shifter and the gearbox aren't stuck. you'd have to get under the car to have a good look. You might also want to check if the clutch cable needs adjustment. A partially disengaging clutch can cause the shifter to get stuck. In your case, this is probably not the issue.
Battery Charger
Aren't you able to just charge each 12V battery individually and put them back in?
Looking For N16 Spare Part
Pretty common issue on this version of the Sunny. A friend of mine ended up purchasing an entire dashboard, just for this part. Try eBay. The Sunny is called "Pulsar" in Australia and you might be able to get one shipped from there. Will be pretty expensive and you might be able to find a complete dashboard locally for that price tbh.
Viva Elite Community
Thanks @kusumsiri. Threads merged. @Devin, there is a known issue in the Viva Elite with the front brake calliper pins. Read through this thread and you will find more info. Like Kusumsiri said, I suggest you get the car checked out immediately. Do not drive with malfunctioning brakes.
Project Moggie - Body & Electrical work
Making good progress @kusumsiri! Keep it up! One thing I can advise you on is to keep the wiring well away from the welding torch. While your tinkerer is cutting out external panels, there might be wires that go through small cavities that'll get torched in the process if not moved away or properly shielded.
- Project A72V
Steering multifunction suddenly not working
Check for a blown fuse first. If that's fine, take it to a good electrician. If you are up for it, you can do a continuity check by using a multimeter. This will tell you if the clockspring inside the steering column is faulty. To do this, you will have to remove the steering column trims near the pedals, locate the wire harness coming down from the steering, use the multimeter terminals on the common pin and each remaining pin while pressing each button momentarily on the steering wheel.
Prius 3rd gen (30 ) 2012 ABS
Usually refers to the modulator, but you never know what our local johnnies mean. ?
I'd like to know the reason for opting to replace the ABS unit in the first place. What's the issue? Was a scan done and error codes revealed?
Alto 800 (2008) - Driver side door needs to be slammed to lock properly
In addition to lubricating, you might also want to check if you can adjust the striker on the door jamb and look all round the door for a twisted rubber moulding/weather strip, or a rubber door cushion that's come off partially.
Any idea about migration agent charges?
Sorry for the delay in responding. The past couple of weeks have been a bit hectic. The relevant assessing authority checks your certificates and stuff with the relevant institutions from which you obtained them. As for work experience, you will be required to talk to your employer and get a letter (letter of experience) from them (you'll have to do this for all your previous employers for up to 5 years I think). The assessing authority usually call up HR or the manager who issued the letter. So yes, there are checks being done.
- Do dreams come true? = YES (Bought a lancer ex)
Perodua Axia is it a good car to Buy ?
Noises are hard to diagnose by description. It needs to be inspected in person to give an accurate answer. However, where does the noise come from? Inside or outside? Engine bay or wheels? Maybe share a video clip?
Nissan March K11 (YOM 2001) IAC valve dysfunction
After a cold start (i.e in the morning), does the engine rev upto about 1500 RPM and slowly settle down to normal as the engine warms up? If the rest of the throttle body is good, and if it is actually the IACV that is faulty, just replace the IACV. There's no benefit in replacing the entire throttle body unless the one on the car has a crack or irreparable damage.
Bump of rear wheels
First check the condition of the tyres. Check for previous puncture repairs that have the repair cord sticking out. Check for pebbles stuck in between treads. Check for bulges in the sidewall. Next, get the rear wheels balanced. Maybe a balancing weight has fallen off causing vibration. If none of them solve the issue, get the rear suspension checked out from a good garage.
rpm problem
Agree. If this started happening immediately after battery replacement, it's probably because the ECU was reset. Driving a few kms in mixed conditions (with AC on) should allow time for the ECU to re learn.
Project Moggie - Disassemble Body Parts
Good luck with the project!
- Documents required to buy a Vehicle Permit and other fees
Hi, welcome to the forum. The "current scenario" is exactly what the OP of the quoted thread has asked. Old discussion or not, the law is the law. The advice given in that thread still applies. @Crosswind, since you are one of the first to respond in the thread, can you please confirm this is correct?
Order Brand New Car
http://bfy.tw/N8JZ
The Potenza is a performance tyre. So softer compound = better grip + relatively faster wear. But like I've said in my RalliArt thread, they're the best tyres I've ever used. Then again my car is mostly a weekender and I prefer the handling and grip over service life. If your car is daily driven, you might want to settle for something for comfort and economy. However, it's your personal preference. The Potenzas will be significantly expensive. Especially if you're talking about RE003.
WHICH octane for VITZ?
Threads merged. Thanks @matroska for pointing out.
Temperature indicator (blue)
Your engine has a Coolant Temperature Sensor. It's basically a resistor that changes it's value based on the temperature of the coolant. The sensor is mounted somewhere on the engine in such a way that it's tip touches the actual coolant that's flowing around in the engine. So as the coolant becomes warm as a result of the engine running, the resistance changes. This signal is interpreted by the ECU. When it reaches a certain value (the operating temperature), the blue light turns off. It depends on the car, if it's petrol or diesel, type of engine and so on. Coolant is under pressure, so it can take more heat than when the liquid is under atmospheric pressure. A general range under normal operating temperature would be something between 90C and just above 100C.
Riding With Learners Permit
Scroll up and read the post by CJ5.
