Everything posted by abiman
Corolla Ce110 Engine Mounts
Hello, I also did replace main engine mount of my CE110, bought for Rs.2700 on 2011-07-22. Still no problem. It was around 18000 at toyota that time. Also did replaced small engine mount near radiator bought for Rs2000/- on 2011-08-07. Still no issue. All of these mounts are new, but I dont remember brand. Main mount was replaced when I replaced T-Belt and water pump. labor was Rs2250/- . (Also replaced 2 lower arm bushes same time and took full day to disassemble, buy and take parts to garage and reassemble) Other mount replacement took 30min and labor was Rs.300/- after replacement of engine mounts I used car for 27xxx km now. I never knew I should replace all engine mounts at once. If I knew I would done that.
Lower Arm Bush, What It Does?
Hello, I was instructed to replace lower arm bushes of my car when I went for wheel alignment. car is Toyota sprinter CE110 1997 please refer to attached picture. My questions are 1. Will it be safe to use car for few times travel in E01 before replacing those? (If it is, I could do it without applying for leave. And I drive within legal limits.) 2. What are the effects on other parts of car (like tires, shock absorbers, breaks) because of these busted lower arm bushes? 3. Is there any specific reputed brand for look for other than Toyota genuine parts? thanks Abiman
Electronic Fuel Saver
HI, not really on topic, but what do you think about attaching rare earth magnets around oil filter? does it make any difference in filtering oil? surely it will not catch non metalic particles.
2C Engine Injector Cleaning
Hi, is it Auto or manual?
Hello, I need your advice regarding 2C engine tuneup, is it necessary? This is because I noticed lot of information in AL regarding fuel system cleaning, tappet clearance (what ever it is ?) adjustment, injector pump cleaning and pressuring and any other preventive maintenance required with 2C engine + mechanical injector pump. Following is my story. Car is Toyota Sprinter CE110 1997 Auto transmission with 2C engine. after I bought car I used it 35000km in little less than 2 years. I think real clock on meter should be around 200000km now. (it was tempered by last owner!). I have never done any of maintenance on engine and I don't think previous owner did any too. Fuel filter (vic) is now used for 22500km. I have K&N reusable air filter and use vic oil filter which changed with every service done at 5000km. engine oil used is mobil mx 15w-40. 50% of distance I traveled in this car is on E01 (after opening E01). there is less than 0.1% driving on traffic. Now my average fuel figure is about 13.4km/l (with AC on all most all the time) . this is figure I checked over 10000km distance and pretty accurate. And mostly I travel alone when on E01. So my question is at current stage do I need to do any of above maintenance services? I think my fuel figures are good and therefore if I let mechanics to do above things is it possible they screw up these average fuel figures? Thanks is advance
Car Security Systems With Realtime Gps Tracker
Got it through friend and installed by my self. took less than 30min to install. Simple all in one unit. I jest had to power it up and configure.
I have one installed on my car. in fact it is GSM/GPS tracker. When I need to track, I call the unit and unit send me text message with current position lat. and Lon. I can then look at the position on google map. It works very well and has lot of other options I do not use much. Anyway it is not the type that can stop car. just tracking device. If I remember corectly, cost me around Rs10000 from china. Unless it is drugs and weapons, and you know how 99.9% of customs officers operate , importing is not much of issue.
Changing The Wiper Motor Speed In Old Car
series resistor to the power line should do the trick easily. power and resistance depends on motor power. More complex Hbridge with PWM will also do the trick more efficiently at higher cost. All depends on motor power.
Building Electric Circuits - Good Place To Buy Stuff ??
You could try, 1. Vicram Plaza No 51 1st Cross Street pettah. (lot of shops with lot of items.) 2. Asia electronics, 1St cross street pettah. (mostly crowded all time.) 3. Unitec, 1St cross Street ( lot of items related to embedded systems, if you work with MCU, MPU)(again mostly crowded and unless you are Muslim, you wont get much attention) 4. Sena electronics, 1st Cross Street. 5. Digital electronics in Vicram plaza (Ariyapala Aiya’s kade) reliable source for good parts and friendly service and I think only Sinhala kade in vicram plaza. 6. YMBA Borella, Senith electronics. (Expensive) 7. there is kade, (which I don’t remember name) at kurusa junction near Moratuwa. (No offence to any one and this is my experience working with hobby electronics over 20 years.)
Express-Way Updates
Tata Nano doing 100km/h on E01
Head Light - High Beam Issue
Hi, Can you please explain, because head light high beam indicator bulb on meter panel works fine with switch. Only head light high beam has issue. if switch has issue then high beam indicator and high beam should behave in same way right? So can it be switch issue? thanks for help.
Hello, I have Issue with headlight high beam of my car. (Toyota Sprinter CE110 1997 Crystal light /Auto) It operates in following way, 1. Low beam works always. No issue. 2. High beam works fine when I pull the head light leaver with low beam switch is OFF and meter panel high beam indicator works fine too. (pass light works fine) 3. When headlight switch is in low beam ON position and operate high beam by pulling leaver, both high beam and indicator light on meter panel works fine. 4. However when I put leaver to high beam on position (pushed down with headlight switch on) meter panel indicator works fine, low beam turn off and High beam will not operate. However some times it works fine. I found one relay named headlight under the hood which turns off headlights (both high and low beams) when relay pulled off and relay operates fine and contacts are good. so my question is, where do you think issue is? does this car has some other fuses/relays separately for high and low beams? where? thanks in advance.
Immediate Help On Prius Navigation
Or may be run OCR for Japanese and use google translate
Engine Heat Indicator
HI, Where did you bought this thermostat? How long it took to install it? thanks
Express-Way Updates
There was no water on the spot. It was clear. (as far as I can remember)
Hello all, When I traveled on E01 today I noticed that my car's (Toyota CE110 1997 Auto) engine heat indicator stayed at about 50% of usual value for full 80km I traveled. (about at 25% of full scale, usually it reach about 50%) However when I hit high-level road, within 1min it reached usual 50% of full scale value. is this usual? or is there something wrong with car? thanks in advance.
Express-Way Updates
First experience on E01 It was great! However, For 80km I traveled, there were lot of (over 50) dogs on the road. (I think they will find new homes soon when they realize there are lots of vehicles traveling.) I was unfortunate to witness one of first accident on E01, It was a van toppled just before (Galle side 1.5km) Horana exit. It seems like happened few min before I reach that point and there was considerable damage to van and two guys were near van. I haven’t seen any injured. There was just enough space on road to pass that point because van was blocking road. It seems like van hit the fence on middle of road and toppled. Also I was behind a guy (I think entered from Galle) who drove Black Prius, and to the full distance of 80km I traveled, he was occupying right side lane, (not only for over take!). I felt sorry for the guy, who had rat brain, no use cursing to him. Just shown amount of education he had, although he drove big car! Also there was one dead dog on road. And some birds. It took me 55min to cover 80km There were only few vehicles on road. (I saw only about 60~70 for 80km I traveled, both directions) After all it was great!
Express-Way Updates
One of my friend told me that even though E01 will open 27th, it will take at least one more month to let us use it (???). He told me that this was told by some minister on radio/TV. Do you guys hear something like this? is it true?
Bad Experience With Sri Lankan Police
I dont think you have any viable and fair option available with authorities. However it would be great if we all can use car black-box (video camera) to record this events and post on youtube with faces of police officers.
Super Sim
1. Yes using for over 3 years. 2. ebay 3. around 5~10USD with Smartcard reader 4. now most of service providers use COMP128 V2 and V3 SIM cards, which cant be cloned. However COMP128 V1 can be cloned easily through A3A8 algorithm hack. I have tried several new SIMs from dialog and mobitel and found all of them use either COMP128 V2 or V3 algorithms in SIM. 5. Yes, I did it may times at home,it is simple process, provided you have COMP128 V1 SIM from service provider. (Simply if you have old sim card, you may have chance to clone it.) 6. Yes, almost every mobile phone supports it. Phone should support STK to use Super SIM. I'm not sure about Apple Iphones, Haven't tried on it. I personally used Super SIM on Android , HTC WM6.5, Nokia Symbian 60, and 40 and other simple phones. 7. read above and it works nice. you cant use two numbers at once. only selected number will be online. Some phones will have small issues with SMS service center, Speed dials, you need to adjust them manually each time you switch number. it takes around 30 to 100 seconds to switch from one number to another and acquire network. hope this helps.
Corolla Rpm Meter
Hi, Probably it will be plug and play case. When i'm playing with my remote start/security system, I found tacho wire under the the meter panel. (which had freq O/P changing with engine RPM). my car is CE110 Sprinter 1997 XE limited. So chances are you already have sensors and every thing wired to meter panel. where did you found new meter panel with RPM meter? what is the price? just for information, I found folding mirror wiring also exists, but no folding switch in power mirror switch panel and mirrors are just power mirrors. cheers
Toyota Ce 11O Fuel Consumption
Hi, My boss did engine overhaul for 2C engine in his CR41 van and cost was Rs80000/- including spares and labor (about month ago). He replaced pistons, lot of bearings, did reboring and sleeve insert and replaced gaskets. (engine was in bad shape with lot of oil burning-about 500ml per 500km, very hard to start and did overhaul only when engine refused to start) So I wonder what cost you 80k more. would you like to share? My car is Sprinter CE110 auto with 2C engine. Although my engine is fine for now,(no oil burn, no smoke, around 12.6~13km/l), I' like to be armed when overhaul become necessary. thanks.
Hid Low Beam On Toyota Ce110 (Crystal Light Model)
Hi, Does anyone used HID lights on Toyota CE110/AE110 car? (model with crystal lights) Will it give more clear front view to driver of 110 without blinding others? (I'm interested about 4300k color temperature.) I know, to get best performance from HID lights, Projector lights or special reflectors required. Will the reflectors in this car can be used with HID lights? please share your experience. Thanks.
Toyota Ce110 Abs Issue
Can some one also clarify front left! is it the left when I'm seated on drivers seat or the left when I'm looking at car from front?
Hello, I have ABS warning lamp ON always when my car (Toyota Sprinter CE110 1997, Crystal lights model, 2C engine) started. The problem was there when I bought car, previous owner cheated me by bridging wires under meter panel. To find out issue I have followed AutoData V3.24 guide and accessed diagnostic information by bridging some wires on OBD port which gave me following 2 Trouble codes through ABS light on meter panel. Trouble code 32: Wheel Speed Sensor, LH front - Signal Trouble code 41: supply voltage low/high I would like to know more about this error codes. Does this codes linked? (LH front wheel speed sensor is not working because of Power supply issue to sensor?) Does any one have any experience on this type of issue in CE110 car? Thank you in advance.
