hatharasinghe
Everything posted by hatharasinghe
  1. Kia Spectra 2001 model Auto City 8-9Km/l DIstances Flat roads 11-12Km/l Hill Side 10-11Km/l Petrol Octane 90.
  2. dear all thanks lot for updating such valuble topic as thesedays we all try to save fuel by adding gadgets and more but still no good results its clear we all done lot of things for the matter.
  3. dear all does fuel injector cleaning fluid work well is it worth or the best thing to cleaning it at garage if any particular good brands in srilanka pls updates as lot of ads telling its good and improve performances such as fuel economy and emissions quality.
  4. Dear all anybody use enzymes to improve fuel economy and engine performance does it really happen as mention in several advertistments in different brands is it worth for paying and if it use for firstime should it use continous pls update me. Thanks.
  5. hi tyre centre guys told me if we put this metal or plastic caps before fix apply grease or such things or else it may happen after sometime i think due to sun or uv rays it becoming some dusty and it fix to valve like superglue so tyre centre guys told at least once a week check all caps loosen and if dust can seen then clean and apply but sure its not practically as forgetting it until air filling.
  6. motor senser may not functioning prpperly just replaced a motor u can but it around 900 with fixing charges.
  7. Dear all I replaced new modified valve covers to my car month ago and yesterday when i went to tyre centre to check the air oh what a mess NO CAP can be removed as all tighten just like superglu apply so all 4 valves had to replaced and tyre centre guy told these caps never use as after sometime it has some dusty particle like cement ant when it heat due to daytime it make terrific bond if it happen never remove the cap unless remove the valve from the rim. here i attached one cap with the valve (actually had to cut to remove) so carefull .
  8. thanks dear all got lot of very good comments thanks u all.
  9. Dear all is it not good for the engine to park the car and AC on for longtime such as 2hrs while engine running in parking mode if any damages to engine or it only the cost of fuel pls explain thanks.
  10. didnt u try AJANTHA MORTORS OR ARUNA MOTORS sometime u can get more informations
  11. Dear friend How can i identify Oxygen Sensor is bad and to be replaced If vehicle pased the Smoke Emission Test does it mean Oxygen Senor is good and even my car shows up as a check engine light or malfunction indicator lamp illuminating in the dash board. Can i check this simply or should i go to garage for OBDII code checker is there any thing can do for me using normal toolkit at home (DO IT YOURSELF) but in my case fuel consumption is ok.
  12. thanks machan this is really good i also want to do this kind of works
  13. Dear Friends i have a Kia Spectra Auto Gear car now when pickup the car it delays and sometime feel "gasenava vage" connect the gear is it problem on gear oil changing or any other matter last week got the smoke test and it said totally ok they told engine in real good condition i changed gear oil 15000KM before and when manually check the colour of the oil it still in red so could u let me know any areas to checkout thanks u all.
  14. hi if the noise continue while driving then the whole set u mentioned to be replace but if it stops little time then sure the beld loosen and loss its tension so replace belt the matter ok better check visually if any wear of the belt if it look shiney then it wear or manually check the tension if not tight then it lossen.
  15. Deal all thanks lot u all update me greatly
  16. dear thanks to update such things as i also not much concern about this so thanks again its our responsible to pay attention until the end thanks again.
  17. Dear All, Is there any effect when disconnect or removing Battery to the ECU unit will it effect to fuel economy as I went to do smoke test at Kiribathgoda Eco and the Manager told if Battery remove or disconnect without giving external supply then ECU loss its data and nextime it may not functioning properly to optimize Fuel economy until vehicle drive at higher speed at least 100kmph then it again self calibrated is this true as i seen when at garages disconnect the battery and even if Engine light display at dashboard to off disconnect and re connect the battery so will it effect to ECU pls update me .Thanks .
  18. better if u want to go lal alawatte his cost not cheap but not ext high but work sure no any hassel i do all my repair of my kia from him
  19. One of my friend Eng. Deeptha Appuhamy, an Automobile Engineer has undergone a training on Hybrid Vehicles in UK. According to him voltage to the motors is 500 V. If somebody touches a wire for repairs without proper tools and safety equipments (such as high voltage glove and boots), it will be a on the spot death. As you know, many of our garages do not have any of these equipments. Also, as Engineers we also try to find the fault as we have some sort of knowledge. Can you see the danger? Furthermore, if breakdown, o not drag the vehicle by another vehicle like we practice in other cases. It has to be towed. Otherwise the system will get overcharged and will get destroyed. Deeptha found a recent case that one local AC mechanic has refilled the AC pump. AC pump in Toyota Hybrids are totally different as they are not coupled to the engine. It runs on electricity. That car's whole electric circuit was short circuited and destroyed as proper oil was not used. He tells that Toyota's Hybrids are better tham Honda's as in Honda's the engine runs (with open valve) even when the vehicle is running on electricity. Hence it is subjected to rapid wear-off. But in Toyota's the engine is completely stopped. If you have any problem on Hybrids, he will help you as a fellow Engineer. You can call him on 0777-383667. Share this information with your friends who use Hybrids as it will help to save a life ir his valuable car. Thanks and best Regards. Hybrid hype Over 400 cars imported in 2010 at a cost of around Rs.1 billion; more new models with better technology to hit the roads with prices dropping By Uditha Jayasinghe Hybrids are becoming ever popular with 2010 statistics showing that over 400 cars have been imported last year costing over a billion rupees. A study on vehicle imports conducted by the Ceylon Chamber of Commerce (CCC) showed that in 2010, 406 hybrid cars were brought into the country. This was for the engine category 1000cc-1500cc, which also had Japan dominating with 63% and Germany trailing behind with 22%. These vehicle imports were done at a cost of Rs.908 million. In the engine category 2000cc-3000cc there were only 29 vehicles imported at a cost of Rs.72 million. Here Japan emerged as a clear favourite with 97% of people preferring Toyota. It is impossible to get the data for the preceding years for comparison because the Customs Department only started making the distinction between hybrids and other cars from 2010. This in itself is a clear indication of the growing popularity of hybrids. However, the Registrar of Motor Vehicles as well as the Motor Traffic Department has not yet started categorising hybrid cars. So far they retain the old categorising by simply maintaining the distinction between diesel and petrol cars without noting the number of hybrid cars that are registered. This has led to confusion over exactly how many hybrid cars were imported during the last few years and when the first car was brought down. Dealers responding to calls from the Daily FT remarked that the Toyota Prius and Honda Insight have become the most popular brands with buyers having the shell out anywhere between Rs.2.5 million –Rs.5 million for a recent model. The most popular amount for a model manufactured in 2009 or 2010 appeared to be around Rs.3.3 million and growing awareness of the cars has brought down prices. Another contribution is the reduction of duty on hybrid cars by the government. In the Budget 2010 duty was reduced to around 15% resulting in prices dipping strongly. Informed sources observed that a hybrid that was sold for around Rs.6 million in 2008 reduced to half its price in 2010. The number of companies issuing hybrids is expected to increase with premier brands such as BMW, Benz and Porsche revealing their hybrid models into the market. Vehicle imports roar by 215% to Rs. 117b in 2010 from Rs. 37 b in 2009 Recording a boom year for vehicle imports 2010 saw a whopping increase of 215% totalling Rs.117 billion of new conveyances on Sri Lankan roads. According to a study compiled by the Ceylon Chamber of Commerce (CCC) analysing vehicle imports to Sri Lanka the vehicle import market is experiencing rapid growth following the revision of import duty structure. It noted that in 2010 the value of imports recorded an unprecedented growth of 215% increasing from Rs. 37 billion in 2009 to Rs.117 billion in 2010. India continues to dominate the Sri Lankan vehicle import market with a share of over 50% followed by Japan accounting for 30%. “The demand for small vehicles is robust. In terms of quantity imported, motor cycles and auto trishaws surpass all other types of vehicles. Each year Sri Lanka imports over 100,000 motorcycles (of engine capacity 50 cc-250 cc),” the report said adding that in 2010 the number of motor cycles imported showed exceptional growth of 97% and for the first time the number imported exceeded 200,000. Sri Lanka imports nearly 40,000 auto trishaws each year, but in 2010, the numbers grew by 194% with import of a record number of over 80,000 auto trishaws (petrol). There is an increase in demand for diesel auto trishaws in 2010 as well, which recorded a phenomenal growth of 427%, starting of course from a low base of over 1000 trishaws in 2009 to over 7000 in 2010. Unsurprisingly, small passenger cars (of engine capacity less than 1000 cc) are also in big demand. The number imported in 2010 exceeded 12,000. The demand for small vehicles for the transport of goods (g.v.w. below 5 tonnes) is also on the rise and in 2010 recorded a growth rate of 480%. Reflecting the rapid growth in the agriculture sector, the agriculture tractors imported in 2010 recorded a growth of 152%. “India continues to dominate the market for small vehicles. Japan still retains its position when it comes to vehicles with higher engine capacity. For example Japan accounts for over 80% of the vehicle market for passenger vehicles with an engine capacity between 1000-1500 cc. However, South Korea has overtaken Japan in supplying passenger vehicles with an engine capacity between 1500 cc to 2000 cc in 2010 accounting for over 60% of imports,” it said. The publication provides a detailed breakdown of vehicle imports to Sri Lanka by type of vehicle, the value, the number and the country of origin for the period 2005-2010. It gives valuable insight into the vehicle import market in Sri Lanka and will be of interest to vehicle importers, insurance companies, leasing companies and banks.
  20. Hi , My car had a problem on Alternater so i gave the car to Magcity at Darly road after 4 days (workingdays ) still they saying not finish just like nromal garage bas talks somebody saying still couldnt find some parts from panchikawatte and one say due to rain one mechanic absent so lot of bla bla then i called to GM then he promised me to complete the job withn that day and could take the vehical around 5pm. their charges fair labour cost 1200 and reconditin alternator with 6month warrenty 10500 but the thing is we have to push them like normal bas. so if any of u plan to put the vehical try to push them or else they may delay. this happened to me last week.
  21. hi sure both cars are too good fuel consumption is around 12-13 km per l depend on the traffic u drive but auto its go down to 10 but compare spare parts u can buy genuine very cheaply like oil filter and air filter even cv joints or any parts very cheap and if u do proper maintenance work ok
  22. this article really good good work very helpful thanks
  23. In my 7 yrs exp KIA or Hyundai car cheap and buying genuine spare parts also very cheap with compare to Japanese if not considering market values the good to buy
  24. pls let me know the best battery brand available as i used several types and not satisfied and whats the best go for seal type or normal one normally im not running more milage per day thanks pls advise me as i fed up with batteries
