Nilantha
Everything posted by Nilantha
  1. not me. if some one want he will do it.
  2. Portable fire extinguisher will be in the market next week .
  3. never used Alto. but my friend have one. no major issues. Alto is a better car? better than Micro trend and Cherry QQ
  4. yes my brother has one. bought for his permit.
  5. don't buy cherry qq. indian ALTO is better than this. sorry don't have time to explain
  6. Turbo for 5AFE????????? but pretty decent nice car.
  7. make sure to take with warranty. also don't buy from panchikawatta. post prices here after check. i will check prices from kurunegala if u want.
  8. how about lifetime after repair? now how many km have done after repair? its ok, but this story related to FB14 for your lucky u spend 150k and it was sucessfull. but if it was not sucessful your cost 150K + 250K
  9. can you put cost comparison? also life time after rebuild?
  10. yes may be kike down cable.but!!!! how many km have u run after conversion? did you change auto oil completely after as son as fix the new gearbox? or do you use petrol gear box?
  11. without changing wiring harnus RPM can fix but it is time consuming job. so no one will take the job to complete. with RPM, the meter board wiring come with 4 sockets. check this picture. but if without RPM it comes as 3 sockets. so if you wish to have clean working and clean wiring better you change with CR41 NOAH wiring harnus. 3C turbo engine not comes with sensors (but it has RPM sensor) but it has Emission control system. when you convert your vehicle to diesel if you fix engine wiring properly you can take 15kmpl when you go long run. this is with RPM Another thing is petrol RPM meter and Diesel RPM meter not equal. petrol RPM meter can't fix with Diesel RPM (Petrol - signal - Digital, Diesel - Signal - Analog)
  12. Stop talking crap you bloody idiot. How wasteful would putting a used tranny be, if it blew up in a couple of months? Even if they let you exchange it, you would still have to pay for labor, filters and fluid. be careful when you take advice from small ppl. also ppl who don't have experience
  13. you check cost. but im not sure you can repair it successfully in sri lanka. other than agents.
  14. repair is only money waist. replace from Japan used one
  15. 24hours for normal dry but one month for cut and polish.
  16. Grate work. appreciate your post.
  17. when after 25000km do adjust tappet clearance. from where did you do injection pump calibration? Demo or Toyota lanka?
  18. if you want to do it perfectly you have to change following 1. Engine & Gear box 2. Radiator 3. Air Filter unit. 4. Silencer 5. Diesel Tank 6. Complete wiring harnus including ECU. if you want RPM you have to change the Dashboard. 7. if your engine EFI you have to change wiring harnus in side the dashboard. 8. Engine mounts 9. front suspension bar set ( i fogot the real name) 10. Battery if you not want to do it genuin you can change the folowing 1. Engine. petrol gearbox can use but you have to change the bell housing. 2. Petrol tank can use for diesel 3. Air filter unit can use. (but petrol and diesel have defferance) 4. petrol Radiator can use (Diesel radiator comes with 3 core, petrol single core) 5. Silancer can modify 6. petrol wiring can modify but you have to fix ECU 7. Suspension bar set can modify. 8. Petrol Engine and Diesel engine RPM has difference. so you have to change meter board if u want to use RPM. most ppl only change the engine and gearbox and modify the rest. but it is not sucessfull.
  19. Toyota Lanka will use Toyota Engine oil.
  20. how many KM have you done after overhaul? did you calibrate the injection pump?
  21. as i told you before. doing adjustments u can reduce the vibration. how your engine mileage now?
  22. who is telling there is no perfect 2C engine? some one was telling here 2C has lot of vibration. so i told reasons to vibration. i think the best diesel engine is 2C (According to maintain cost, fuel consumption etc.) it has fixed to lot of models of toyota CE100, CE110, CE192, CE212 carina, Caldina, crown, vista, CR27, CR36, CR41, etc. also when converting Europe petrol vehicles to diesel ppl mostly used 2C
  23. yes proper way is to do adjustments. but expensive. normally toyota lanka takes around 35000/- to calibrate injection pump and so on. so ppl running with some vibrations (also telling with every one 2C engine is not good have vibrations and bla bla). as a goda wedakam some one can change flywheel. it can buy around 5000/-
