Guys,
I have serviced my car in the afternoon and found out some of bushes in the under side of the body are missing.
I'm pretty sure they were there on my last service.
They are some rubber caps covering the holes in the body.
Will there be a place to find these?
post-15869-031029200 1298381285_thumb.jp
Well Darley road people carry standard size bushes. Else the only place I can think of is the agents. These little things can often be VERY hard to find !
these are some types of caps.
I wonder how they have get lost.4 are missing.
High pressure applied probably. They might also fall off on impact. You should also consider how necessary they are. If they plug, drain holes in the floor then you definitely need to replace them. If they are a form of vanity item on the undercarriage maybe not.
Thanks Don.
floor carpet seems to be getting wet due to these .Specially the sponge type material below the carpet.
Visit delkanda, just two or three building next to highlevel plaza. I found they useful in fixing missing bushes in my Passo.
Thanks Don.
You definitely need a quick solution then. If suitable bushes are not found, at least cover up the holes using duct tape as the water under the carpet will lead to surface rust. Also see if the bushes were pushed in and somewhere under the carpets !
