hay theres no japanise spares here arround right? tech motor says that bushes comes from thaiwan. if you need to go for the genuine one have to replace whole arm. one arm costs 10900 in stafford. its too much i think. are there any place to buy japanise bush? i dont think so.
Dear Bro,
Some time back I had a problem with my ek3 lower arm bush and I got replace with a malaysian made bush and the job was done by Waruna at Kesbewa. It was the same story like you said that the agent had the whole arm. After 02 or 03 months same sound came and It was found the bush has partially come out from the housing. At last I happened to put a brand new arm and costed me around 12000 Rs in some where 2000.
I advise you to put the arm instead of bushes for a long lasting solution.
Edited by jaga
When It comes to bushes and shocks, are there impacts on them if the tires used are low profile? Any experiences you guys had?
lower the profile, more the impact on shocks and bushes.
Dear Bro,
thanks bro. but i already purchased thailand bushes from tech motors. will c after replace them. have to do the fixing thing very carefully using a press. otherwise the isse u said will come for the defa.
thanks anyway.
thanks anyway.
I guess there is a limit to the number of times you can get away with changing only the bushes. On flip side you do get the more expensive 'made in japan' stuff as well
  • 10 months later...
guys i replaced all my bushes with thailand made bushes from tech motors.replaced shocks with tokico shocks.but the ride is not smooth."daga daga: sound comes.I really dunno what to do cuz to replace all the bushes it costed me around 35 with the labour charges also.is there any specialist for me to go n show my car? i need a smooth ride.pls help
Did you use Gas shoks or Hydraulic shocks and was the part number correct for your car? When does the noise come? when going over pot holes or in normal driving?
For the bushes you have a 3rd option. Try finding a used arm with good bushes (you've to check the bush thoroughly) from delkanda area.
I did this for the corolla about 2.5 years back and the bush is still holding up. Where as when replaced the bush only, even the Japanese ones brake within a year (mostly in 6 months or so). (same as your's bush only is not available from the agents and the whole arm costs 17k )
bro did u check sway arm bushes?
I also had similar issue sometime back(Eg8). i had kyb in front and tokico in rear(gas). But it was really uncomfortable on non carpeted roads. my mechanic told me that its a common issue with those shocks and need to hav genuine shocks to get that smoothness. Actually it was a real shock :action-smiley-060: :action-smiley-060: to me due to the price of genuine shocks. so i got recon 4 shocks from us motors for 20k with coil springs and belive me threre is massive difference in ride comfort.( you need to find shocks from a same vehicle ,if you r goin for recon onces). Now almost one year and still doin wel.
Edited by H.C
guys thanx alot for the concern.
Bro those are gas shocks.I bought the shocks from tech motors stating my car model.tech motors people are honda people so they cant go wrong right?
Um drowned at the moment guys.Cant afford another big amount at the moment.but thanx will try that once i get some money again if until that the prob persists.
Bro actually this is my first car so i dont have much of a mech knowledge.but the mechanic said he replaced all the bushes and he is a reliable person.anyways i'll check on sway arm bushes.how much would they cost? and could it possibly be the reason??
