Can anyone please tell me what is the type of coolant used by Staff**d for Honda Civics. I bought a used civic and the radiator reservoir is almost empty.
There is no such specific coolant. You can either use Wurth or Caltex pre-mixed solution. Or you can buy Honda specific coolant from the agents. However if the reservoir tank is empty, you better do a check on your coolant circuit to make sure thee are no leaks.
What year/model is the car? I guess they use genuine Honda Coolant. My FD takes Honda Long Life Antifreeze/Coolant which is good for 200k Km`s (pink colour stuff). I`m sure any good brand would be ok though, as long as it`s a non-silicate formula.
Anyway, If i were you I would flush the system and refill rather than topping up.
  • 4 weeks later...
The Coolant used at Staf is Caltex Extended Life Coolant. I think you don't want to use an Antifreeze coolant. If you want go for a non-silicate stuff. Otherwise ethylene glycol based coolant is OK.
1+
was using wurth until very recently.
now using caltex premixed
