Dear friends,how do u reduce fuel consumption with A/C....? If I increase the A/C to higher value,would it consume more fuel or only the blower works hard...?
And what's the meaning of the 'ECON' button
pls help with answers...
thank you.
thank you.
I asked Uncle Google and he pointed me to these links
http://www.toyotanation.com/forum/showthread.php?p=1276889
http://www.popularmechanics.com/cars/how-to/4281039
I suggest you too, make friends with Uncle Google.
thank you.
when the ac is on...the load on the engine is more since it has to run the ac compressor...means more power is needed = more fuel burnt.
If you increase the cooling level the compressor will be running for lot longer to maintain those temps burning extra fuel
econ mode on most cars kicks the ac off a bit sooner saving fuel but giving less cooling.
Isn't the econ button's function same as the recirc mode? :huh:
Nope econ is more like a regulated/manipulated thermostat and recirculation button (or lever) restricts/minimize fresh air intake to system,instead uses the a large amount of already cooled air from cabin inside.
MINIACE
