All
My EK3 – 98 exi had a charging system issue and solved by replacing diode plate in side the alternator and battery . now charging ok.
How ever I noticed the engine RPM on Idle stage has been reduced and looks it now around 600 with out the AC off.
I ‘m not sure this happens after fixing the alternator issue or not.
Repairing the alternator may effect engine RPM? Tight belt or continues charging the battery?
What is the standard RPM for EK3?
sira
All
sira
Rpm should be around 900.wts the Rpm with A/c?
Not 100% sure.. but after repair now alternator has more resistance as it start recharging your battery. This can have slight impact on RPM.
