Nissan March K12 Door Lock Actuators ?
our nissan march k12front passenger side door and rear driver side door lock actuators are not working . .
reaming actuator are working good . . .
where can i find used or second hand door lock actuators in COLOMBO ?
our car has intelligent key system so, are there any differences between actuators with intelligent key system and actuators in a car which doesn't have intelligent key system ?
thanks a lot in advance. . .
6 answers to this question
You can check at NIN au*o ele***cals Delkanda.
Edited by rover
For these issues I go to Th#raka Auto in delkada.They do a very good job,but they take a bit of time.If not they are good
what is wrong with them? they're permanently locked / permanently unlocked / sometimes work and sometimes don't (sticky) / something else?
don't specifically know about March, but usually the "intelligent" stuff is with a ECU that decides to send lock / unlock signals to the lock unit. however the locks might be different between models with / without central locking
btw if both stopped working at the same time, then it could be a wiring issue.
This ECU stuff makes me glad that i chose a non intelligent key march, as it has become older now :rolleyes:
