September 1, 201115 yr i didnt see any one working on this. only 2-3 people wear the seat belts. hope Officers are still sleeping..
September 1, 201115 yr Pure my personal view..!! The Party that should keep the law never follow the law, I have never seen these drivers in 119 Police cars with seat belts on at all. Not even the DIG vehicles or the IGP vehicle wear them. Now the same party are going to catch the other drivers not wearing seat belts? Bu*l S*%t...
September 1, 201115 yr Is there any reason actually NOT to wear seat belts? Unless it causes physical discomfiture ...
September 1, 201115 yr Is there any reason actually NOT to wear seat belts? Unless it causes physical discomfiture ... Not unless you're pregnant.
September 2, 201115 yr http://documents.gov.lk/Extgzt/2011/PDF/Aug/1718_12/1718_12%20(E).pdf Edited September 2, 201115 yr by jerryda
September 2, 201115 yr Not unless you're pregnant. Damn I look pregnant with my 'prosperity' belly .. but never caused no issue with the seat belt!!! So, if you're wearing seat belts, no need to worry about getting copped eh? I started wearing belts a couple of years back and now habitually that's the first thing I do when I get in to a vehicle. If I'm not wearing a belt, it almost feels like I'm naked!
September 2, 201115 yr One of my friends hates wearing seat belts. But his car gives a warning beep continuously if the seat belt is not clipped, and itโs very annoying. So what he does is, grab the belt form the passenger side and clip it on to his side. Iโm not making this up.
September 3, 201115 yr This video reminded me something happend a long ago. I was driving wearing my seat belt with one of my annoying ex's on the front passenger seat. She who often used to make fun on me about wearing belt,wasn't wearing her as usual. I was driving at a lower speed and suddenly a poor dog appeared on the street,I hit brakes,throwing her on to the windscreen. The dog was saved,windscreen was fine but the girl got a lump on her forehead. I am just saying this 'coz many people think that seat belts are needed only on high speeds.NO! It's a wrong idea.
September 3, 201115 yr Yeah this is pure true techlove. for our safe we need to wear seat belts.no one need to push us for that. in the first event it will be bit uncomfartable. but if we practice then it will be ok. my suggestion is lets start it from Au.. La.. webportal. it wii take only few second but save a valuable life.. Hope other's will agree with me..
September 3, 201115 yr What can be done if one is short (say less than 5') and when the seat belt is worn, rather than the belt going over the shoulder, it goes under the side of the chin and neck and sometimes touches the ear ? Is it OK to wear the belt like this or can even a slight jerk cause neck injury when the seat belt is worn as described above? Is the only solution to use a cushion to raise the height so that belt is over the shoulder? (btw, this is for adults. So not sure if booster cushions will be OK or if they are available in SL. So I guess it will be just a typical cushion) Any other practical solutions to above problem please ? (for e.g. is lowering seat belt fixing point on door pillar at a garage advisable ?, any special type of belt that can be used ?, I ask because some passengers are reluctant to use any type of cushion and prefer to opt out of seat belts - which is not safe) Edited September 3, 201115 yr by eyepea
September 3, 201115 yr What can be done if one is short (say less than 5') and when the seat belt is worn, rather than the belt going over the shoulder, it goes under the side of the chin and neck and sometimes touches the ear ? Is it OK to wear the belt like this or can even a slight jerk cause neck injury when the seat belt is worn as described above? are you an oompaaloompa?
September 3, 201115 yr What can be done if one is short (say less than 5') and when the seat belt is worn, rather than the belt going over the shoulder, it goes under the side of the chin and neck and sometimes touches the ear ? Is it OK to wear the belt like this or can even a slight jerk cause neck injury when the seat belt is worn as described above? Is the only solution to use a cushion to raise the height so that belt is over the shoulder? (btw, this is for adults. So not sure if booster cushions will be OK or if they are available in SL. So I guess it will be just a typical cushion) Any other practical solutions to above problem please ? (for e.g. is lowering seat belt fixing point on door pillar at a garage advisable ?, any special type of belt that can be used ?, I ask because some passengers are reluctant to use any type of cushion and prefer to opt out of seat belts - which is not safe) Lower the height on door pillar. If you are shorter than that you should get yourself a child seat with a harness.
September 3, 201115 yr What can be done if one is short (say less than 5') and when the seat belt is worn, rather than the belt going over the shoulder, it goes under the side of the chin and neck and sometimes touches the ear ? Is it OK to wear the belt like this or can even a slight jerk cause neck injury when the seat belt is worn as described above? Is the only solution to use a cushion to raise the height so that belt is over the shoulder? (btw, this is for adults. So not sure if booster cushions will be OK or if they are available in SL. So I guess it will be just a typical cushion) Any other practical solutions to above problem please ? (for e.g. is lowering seat belt fixing point on door pillar at a garage advisable ?, any special type of belt that can be used ?, I ask because some passengers are reluctant to use any type of cushion and prefer to opt out of seat belts - which is not safe) No I wouldn't advise you to do that as messing with safety gear is generally ill-advisable, plus changing the mounting points would mess things up for taller passengers wouldn't it? Buy a seat belt adjuster off ebay and use it to adjust the belt so as to hold the shoulder strap in its proper place over the shoulder and away from the face and neck of your passenger. They are sold at retail stores like Walmart for $10 as well, so if you can work out the logistics that might be a better option as that way you know you're buying a somewhat reputable product that has been approved for sale in the US.
September 4, 201115 yr Did everyone miss the part where it said that Seat Belt provisions do NOT apply to persons less than 150 cm tall?
September 4, 201115 yr Did everyone miss the part where it said that Seat Belt provisions do NOT apply to persons less than 150 cm tall? some people choose to wear seatbelts even if they are not forced to do so by law
September 4, 201115 yr Thanks very much for all the info. Most cars I have seen, the seat belt mount point on the door pillar is height adjustable. My one, it is not ... child seat with a harness. Guess this will depend on the space available and max weight limit on the seat . Afaik weight limit spec is indicative of the force the harness can withstand in a crash. Please advice if incorrect. ... Buy a seat belt adjuster ... adjust the belt so as to hold the shoulder strap in its proper place over the shoulder and away from the face and neck ... Aha seems a nice solution.
September 4, 201115 yr some people choose to wear seatbelts even if they are not forced to do so by law Agreed!
September 7, 201115 yr Isn't the law coming in to effect on 1st Oct? haha it was made compulsory a while ago,suddenly a date has come up,this is rubbish,just wear it if u want to..thats it
September 8, 201115 yr Apparently Lorries need to have seat belts after the 1st of October as well.. Apparently due to the number of accidents . When did wearing seat belts prevent accidents?
