kmcsb Posted September 9, 2011 Posted September 9, 2011 hi everybody, Im planing to install an xenon hid kit 8000k for my Honda civic eg8 94 model..I've just loafing around to find a suitable bulb type for that..but unfortunately i couldn't find the right one...some are saying its OK with H4 ,and some are H7,H4-3 ..so im little bit confused.. im planing to buy it in Saudi when i go there..but im little bit upset because which bulb should i need to buy.. if anyone know pl z help me ASAP.. thanks... Quote
The Stig Posted September 9, 2011 Posted September 9, 2011 hi everybody, Im planing to install an xenon hid kit 8000k for my Honda civic eg8 94 model..I've just loafing around to find a suitable bulb type for that..but unfortunately i couldn't find the right one...some are saying its OK with H4 ,and some are H7,H4-3 ..so im little bit confused.. im planing to buy it in Saudi when i go there..but im little bit upset because which bulb should i need to buy.. if anyone know pl z help me ASAP.. thanks... Im not an expert here but i believe its H4 One easy way to find out is to remove the existing bulb, if it has 3 connectors its H4 and if it has only 2 its H7 H7 H4 Quote
kelum_wj Posted September 10, 2011 Posted September 10, 2011 If its the stock headlamps its H4. If its Projector lights the High beam is H1 and Low beam is H7 if I remember right. Also I would advise you to go for 6000k as 8000k would be useless in bad weather . Quote
shanX Posted September 10, 2011 Posted September 10, 2011 It is H4 for stock lamps. 6000k please Quote
kmcsb Posted September 10, 2011 Author Posted September 10, 2011 Thanks for u all fore replying me.. i tired h4 bulb ..but it doest fit me well..that bulb's back aluminum circle is too large..so i cannot put it ald its not fitted....some guy say its h4-1..and i remove my original halogen bulb its named as 3n.... so what do u all think..?? as it support h4-3 or what... Quote
The Stig Posted September 11, 2011 Posted September 11, 2011 (edited) Thanks for u all fore replying me.. i tired h4 bulb ..but it doest fit me well..that bulb's back aluminum circle is too large..so i cannot put it ald its not fitted....some guy say its h4-1..and i remove my original halogen bulb its named as 3n.... so what do u all think..?? as it support h4-3 or what... What ? H3 looks like this I highly doubt you can fit that to your car. Its not the shape of the bulb, H is about the shape of the holder and the shape of the bulbs connectors. If you want to put H7 or H3 you will have to change a lot of things in your car and if you install H7 or H3 only your low beams will work cause they have only one filament. CAn you post a pic of your current bulb ? Edited September 11, 2011 by The Stig Quote
kmcsb Posted September 12, 2011 Author Posted September 12, 2011 I THINK BULD TYPE SHOULD BE H4H.. WHEN I INSTALL H4 XENON IT DOESNT FIT CORRECTLY..BECAUSE COMPARING H4H's base is smaller than H4... Quote
The Stig Posted September 13, 2011 Posted September 13, 2011 Ya i did some research and it seems you are right, the JDM version has H4H bulbs. They are JDM market only so would be tough to find here or on ebay for that matter. I was only able to find 3 results, check these out http://cgi.ebay.com/ebaymotors/H4H-SLIM-Xenon-HID-Conversion-light-Kit-JDM-Cars-/150295952472?pt=Motors_Car_Truck_Parts_Accessories&hash=item22fe563c58 http://cgi.ebay.com/ebaymotors/h4h-jdm-front-end-hid-xenon-conversion-ek-ej-eg-civic-/110662223708?pt=Motors_Car_Truck_Parts_Accessories&hash=item19c3fb875c http://cgi.ebay.com/ebaymotors/JDM-H4H-HI-LOW-702K-XENON-HID-KIT-6000K-EG6-DA6-EF8-9-/280731700868?pt=Motors_Car_Truck_Parts_Accessories&hash=item415ce9ce84 Also the second option is to get somee bulbs down from someone who is in or visitiing japan. The third and the final option is to cut the outer ring of the normal H4 yourself, check out this link http://floridahondacrew.com/diy-do-yourself-guides-faqs-tips/11069-diy-eg-jdm-head-light-usdm-light-bulbs.html Quote
