pubchi Posted September 27, 2011 Posted September 27, 2011 Hi guys, Recently I bought a 110 and had to do some repairs. After servicing the AC I found that idle rpm is fluctuating. (while AC is on). I think normally the RPM should increase after turning the AC ON. right? But in this case without AC my RPM is 750. With AC ON, it drops below 500. Do you have any experience on similar cases? Will a normal engine tune up solve the issue? Highly appreciate your views. Rgds. Quote
jdnet Posted September 27, 2011 Posted September 27, 2011 (edited) RPM decreases when the compressor kicks in. It's a normal process. B worried only when the engine tries to die or is constanly bbelow 500. Edited September 27, 2011 by jdnet Quote
pubchi Posted September 27, 2011 Author Posted September 27, 2011 RPM decreases when the compressor kicks in. It's a normal process. B worried only when the engine tries to die or is constanly bbelow 500. Yes, engine tries to stop. That's why I'm worried. Rgds. Quote
pubchi Posted September 27, 2011 Author Posted September 27, 2011 what are the repairs you had done? Serviced the AC.- changed compressor and cooler Other things - t belt change, ABS motor replacement, replaced one hose (don't know what is it) to engine which was hardened and damaged Rgds. Quote
luckey007 Posted September 27, 2011 Posted September 27, 2011 Check your vacuum line to the idle speed increasing gadget and its power supply line.BTW do you feel tight break pedal? If its not most probably electric issue. i Quote
jdnet Posted September 27, 2011 Posted September 27, 2011 +1 on checking the vacuum lines. Somethines it's as simple as that. Quote
maheshw Posted September 27, 2011 Posted September 27, 2011 Check your vacuum line to the idle speed increasing gadget and its power supply line.BTW do you feel tight break pedal? If its not most probably electric issue. i well i thin this is what called AC idle up in general.pleae check whher the unit it working properly. Quote
Wasa Posted January 10, 2014 Posted January 10, 2014 could anyone tell me please a good reliable place (Colombo or sub urb) to check / change timing belt of my corolla 110. It has small oil leak from the engine and when serviced, their (mechanical) guy told it should be from oils seals near the timing belt assembly area of the engine. So I need to show to a good mechanic and correct. If need, change the timing belt too as I can't rely on odometer / previous owners. Thanks Quote
The Don Posted January 10, 2014 Posted January 10, 2014 could anyone tell me please a good reliable place (Colombo or sub urb) to check / change timing belt of my corolla 110. It has small oil leak from the engine and when serviced, their (mechanical) guy told it should be from oils seals near the timing belt assembly area of the engine. So I need to show to a good mechanic and correct. If need, change the timing belt too as I can't rely on odometer / previous owners. Thanks Wasa changing the timing belt on a 110 is something most mechanics are capable of as the car is very popular. Only thing to make sure is that you use a genuine Toyota timing belt. Where do you live? Quote
