preethie Posted September 29, 2011 Posted September 29, 2011 I HAVE A NISSAN WINGROAD AUTO 2002 MODEL CAR. IN THE MORNNING AFTER START WHEN ENTER TO D AND PRESS THE ACESELARATER CAR IS NOT MOVEING. BUT AFTER CHENAGE THE GEAR POSITIONS FRONT AND BACK AND AGAIN ENTER THE D IT IS MOVEING. I WANT TO KNOW WHAT THE PROBLEM IS THIS. Quote
Simplelife Posted September 29, 2011 Posted September 29, 2011 When was the last time you changed the ATF? Quote
preethie Posted September 29, 2011 Author Posted September 29, 2011 Really i dont know because last week i bought this. Quote
nano31 Posted September 29, 2011 Posted September 29, 2011 (edited) Just check If the car moving when u put the gear to 2,L or even R and what happen if you keep the gear in D and accelerate the engine? is it moving after a little jerk? First of all just try changing the ATF and cleaning the filter but DO NOT add ATF treatment fluids to ATF. Check if there is an electrical problem. If above measures failed most probably the fault in the gear box it self (Mostly worn,hardened internal oil seals leading to pressure leakage). You could rebuilt the autobox with warranty or replace with used autobox at your own risk. Edited September 29, 2011 by nano31 Quote
preethie Posted September 30, 2011 Author Posted September 30, 2011 Thanks i will change the atf and see it..... Quote
