sagu Posted December 26, 2011 Posted December 26, 2011 Why Honda insight is coming with 1300CC..? is it down grade performance (speed, pick up) compare with Toyota Prius (1800CC)..? Quote
Uditha88 Posted December 27, 2011 Posted December 27, 2011 Why Honda insight is coming with 1300CC..? is it down grade performance (speed, pick up) compare with Toyota Prius (1800CC)..? Initially Insight came with 1.3 L engine but now also available in 1.5 L Don't try to compare 1.3 L Insight with a 1.8 L Prius. No point of such comparison. Prius too available in 1.5 L engine. Quote
sagu Posted December 27, 2011 Author Posted December 27, 2011 Thanks mate. But why do you say not to compare..? I want to know is there any performance difference between Insight and Prius Quote
Pericles Posted December 27, 2011 Posted December 27, 2011 Thanks mate. But why do you say not to compare..? I want to know is there any performance difference between Insight and Prius Then google the performance numbers and compare. Quote
AbeysinghE Posted December 27, 2011 Posted December 27, 2011 Thanks mate. But why do you say not to compare..? I want to know is there any performance difference between Insight and Prius What I have experienced practically..Prius 1500 cc and 1800 cc both perform well ahead of Insight...But even if insight is with 1300 cc engine that doesn't mean that Insight has a very low performance than Prius..both performs good enough for the purpose those car were designed...The other point is prius fuel efficiency is better than insignt..What I feel is Prius's weight to engine capacity ratio is slightly better than the insight.. Quote
