last two days i feels ,when i start the engine car gets vibrate unusually...having 94 carb model..it normally rasibg a few minutes and back to normal beacuse of auto choke feature..i thnik its normal...(discussed last topic)..
but question is when it comes back to idel (normal) feels getting vibrate..what do u thnik guyzzz?????
is it 4m the choke or????
is it a choke porblem should i need to replace or can it repair??? hw much it will be...???
should i need to go honda mechanic like upul or can be done from normal garge guy.....???
plz help
plz help
'kmcsb',
Most Mechanics understand carburetor engine problems. easily repairable.
Get a opinion from a good mechanic for your vibration problem.
Sylvi Wijesinghe.
plz help
can be due to a low RPM or a bad engine mount :) can be many reason or even maybe the car running on less then 4 cylinders in ideal. take it to a honda guy if can, else take it to a normal micanic. but always get a 2nd opinion.
'kalinga',
There is some truth what you say one cylinder may be not working at low RPM. due to faulty plug or some other problem on that cylinder.
Bad engine mounts also contribute for vibration.
Sylvi Wijesinghe.
check plug wires as well.. one of them might be loosen or some thing. but better option is checking with a garage guy since there may be so many problems which cause for vibration.. as so many guys said it might be a bad engine mount even..
