January 20, 201214 yr How to Install back Door top break light? how to set connectivity ? how to lay wires ? prices?
January 20, 201214 yr How to Install back Door top break light? how to set connectivity ? how to lay wires ? prices? Well you find one that is suitable for your car and wire it in sequence to your brake lights. It's actually not that difficult and any competent auto electrician will do the job.
January 21, 201214 yr How to Install back Door top break light? how to set connectivity ? how to lay wires ? prices? 'ColomboRox', Do you have a back door light. There are LED lights or normal back door light you can buy in the motor spare parts shops. Some are with pasting type others you have to drill holes and fix. The two wires from the back door light you have to earth one end other to your brake light power line. As don says get a competent auto electrician to do the job. Sylvi Wijesinghe.
