I have a Hyundai Stellar 1986 Module, which has 1500CC Mitsubishi (4G33/32) engine. (I’m not sure but its Timing Chain module)
My issue is that the cylinders and Piston rings has worn out and my mechanic advice me to do the following.
1. Remove existing sleeves and fix new sleeves, polish new sleeves to the existing piston size hence existing pistons are originals, good and no need to replace which will cost me 10,500/-.
2. Replace Ring set with Standard one cost 2,500/-.
3. Replace Began Bearing set to a Standard one cost 1,900/-
4. Purchase an engine overhaul kit suits to my engine cost 3,800/-
Pls. advice me on followings.
1. What you’ll think about fixing sleeves?
2. Is it durable?
3. If yes how many Km’s average?
4. Will this solve oil burning and give good compression?
5. Will this low down the engine noise and make it smooth like a new car?
6. Finally will this give me good fuel consumption?
Surrounded by various different nice car models in Germany but still fascinated by the Presea, Bluebird U13 and the Mark II.. The first cut is the deepest.. Baby I know, the first cut is the D he he he
LancerL
Dear Experts,
2. Is it durable?
Thanks in advance for your valuable advices!!!
Regards,
LancerL
13 answers to this question
