I have a Hyundai Stellar 1986 Module, which has 1500CC Mitsubishi (4G33/32) engine. (I’m not sure but its Timing Chain module)
My issue is that the cylinders and Piston rings has worn out and my mechanic advice me to do the following.
1. Remove existing sleeves and fix new sleeves, polish new sleeves to the existing piston size hence existing pistons are originals, good and no need to replace which will cost me 10,500/-.
2. Replace Ring set with Standard one cost 2,500/-.
3. Replace Began Bearing set to a Standard one cost 1,900/-
4. Purchase an engine overhaul kit suits to my engine cost 3,800/-
Pls. advice me on followings.
1. What you’ll think about fixing sleeves?
2. Is it durable?
3. If yes how many Km’s average?
4. Will this solve oil burning and give good compression?
5. Will this low down the engine noise and make it smooth like a new car?
6. Finally will this give me good fuel consumption?
Surrounded by various different nice car models in Germany but still fascinated by the Presea, Bluebird U13 and the Mark II.. The first cut is the deepest.. Baby I know, the first cut is the D he he he
What is the deal with the car market these days!!
I went to check on a Jimny, 2016 2nd owner and he's hellbent on 6.8mil for the thing,
approx 50000km+ mileage
Needs tyres, rear shock absorbers leaking and there has been an aircon repair as well.
(Approx 400k LKR in pending repairs making the total 7.2mil)
Whereas a brand new one can be imported between 8.2-9.5 given the grade and winning bid.
I ponder what the mentality is of the people of this country...🤣
LancerL
Dear Experts,
2. Is it durable?
Thanks in advance for your valuable advices!!!
Regards,
LancerL
13 answers to this question
