civicferio Posted February 25, 2012 Share Posted February 25, 2012 Dear all, I have fluctuating idle rpm issue and I want to know, someone already solved this issue by changing the IACV. AFAIK this issue is related to the IACV and I cleaned it several times but still it exists. Thanks. Quote Link to comment Share on other sites More sharing options...
prasa Posted February 27, 2012 Share Posted February 27, 2012 On 2/25/2012 at 4:58 PM, civicferio said: Dear all, I have fluctuating idle rpm issue and I want to know, someone already solved this issue by changing the IACV. AFAIK this issue is related to the IACV and I cleaned it several times but still it exists. Thanks. On 2/25/2012 at 4:58 PM, civicferio said: Dear all, I have fluctuating idle rpm issue and I want to know, someone already solved this issue by changing the IACV. AFAIK this issue is related to the IACV and I cleaned it several times but still it exists. Thanks. Check Your Radiator Fans are Working Fine....or blowing pressure in both fans Quote Link to comment Share on other sites More sharing options...
Ralph Posted February 27, 2012 Share Posted February 27, 2012 Did a full EFI tuneup. problem solved for myEK3. Quote Link to comment Share on other sites More sharing options...
civicferio Posted February 27, 2012 Author Share Posted February 27, 2012 On 2/27/2012 at 10:39 AM, Ralph said: Did a full EFI tuneup. problem solved for myEK3. Can you please tell me what have they done for full EFI tuneup? because i did a tuneup. ( cleaned IACV , cleaned TB ) Thanks Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 5, 2012 Share Posted March 5, 2012 may be u gotta change ur IACV bro.anyways check ur idle up sensor too.i have the same issue so i bought a new throttle body because they dont sell recon IACV valves separately.anyways dint try it.will change and let u know if it solves my problem Quote Link to comment Share on other sites More sharing options...
civicferio Posted March 5, 2012 Author Share Posted March 5, 2012 On 3/5/2012 at 3:53 PM, prvnrox said: may be u gotta change ur IACV bro.anyways check ur idle up sensor too.i have the same issue so i bought a new throttle body because they dont sell recon IACV valves separately.anyways dint try it.will change and let u know if it solves my problem Thanks. Quote Link to comment Share on other sites More sharing options...
MeanGreenZ28 Posted March 5, 2012 Share Posted March 5, 2012 check to see if any of your vacuum hoses were left unplugged or there's a vacuum leak at your intake or throttle body after you tuneup Quote Link to comment Share on other sites More sharing options...
maheshw Posted March 6, 2012 Share Posted March 6, 2012 #5 prvnrox Posted Yesterday, 09:23 PM may be u gotta change ur IACV bro.anyways check ur idle up sensor too.i have the same issue so i bought a new throttle body because they dont sell recon IACV valves separately.anyways dint try it.will change and let u know if it solves my problem How much you have cost for the new tb ? ipb.global.registerReputation( 'rep_post_197807', { domLikeStripId: 'like_post_197807', app: 'forums', type: 'pid', typeid: '197807' }, parseInt('0') ); Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 18, 2012 Share Posted March 18, 2012 no machan my mech is too busy these days so couldnt get it fixed yet!um waiting with the tb to get it fixed! :S Quote Link to comment Share on other sites More sharing options...
sira Posted March 18, 2012 Share Posted March 18, 2012 (edited) Bro Please give me more details. 1. is this happens when the engine is cold or warm? 2. When you on the AC? I had similer issue with my car, it spee going high every 3 sec time. so the issue is Idel up valve is blocked, so it can be corrected easly, malabe guy is fixed for me. sira Edited March 18, 2012 by sira Quote Link to comment Share on other sites More sharing options...
blkr6 Posted March 18, 2012 Share Posted March 18, 2012 more likely its your throtle position sensor but i cant say it until i see it or get a better discription of whats happening. Quote Link to comment Share on other sites More sharing options...
MkX Posted March 19, 2012 Share Posted March 19, 2012 On 3/18/2012 at 7:04 PM, blkr6 said: more likely its your throtle position sensor but i cant say it until i see it or get a better discription of whats happening. Yes.. I had the same issue and it was TPS not IACV. Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 19, 2012 Share Posted March 19, 2012 machan if its the sensor the check bulb lights right?? Quote Link to comment Share on other sites More sharing options...
MkX Posted March 20, 2012 Share Posted March 20, 2012 On 3/19/2012 at 4:05 PM, prvnrox said: machan if its the sensor the check bulb lights right?? Well not necessarily. The reason is that ECU reads wrong Throttle position and either increase or reduces air/fuel mixture. This will cause the RPM issue. You can be more certain if it happened when car moves at certain speed. Like in my case car suddenly start quick jerks as RPM goes up and down quickly without changing the throttle position. So it can be either of senors. Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 20, 2012 Share Posted March 20, 2012 i took my car to a mech in gampaha.he is working at stafford.he said if was the idle up sensor or the tps then the check light will come up.so i thought ok may be its the valve then.anyway with the new tb i got the tps too Quote Link to comment Share on other sites More sharing options...
blkr6 Posted March 20, 2012 Share Posted March 20, 2012 you can always can clean the IACV and see whether there are any improvements. Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 20, 2012 Share Posted March 20, 2012 i tried cleaning the IACV bro! held the rpm for few hours but no luck! Quote Link to comment Share on other sites More sharing options...
MkX Posted March 21, 2012 Share Posted March 21, 2012 (edited) On 3/20/2012 at 5:25 PM, prvnrox said: i tried cleaning the IACV bro! held the rpm for few hours but no luck! I'm confused. Civicferio started the thread and but prvnrox haven't given much details about this problem. @prvnrox would you mind giving more details of the problem you have. I noticed you have already bought new TB. Did you change it? What RPM range it fluctuate? Does it change only at IDLE or when you driving too? If you can give us more details, we will be able to share some knowledge. Because I went through this IACV and TPS issue for quite some time and solved the problem with changing TB. Also your TPS can malfunction without CEL giving any indication. Because it works in voltage range and error code only appear when it goes below the threshold AFAIK. Edited March 21, 2012 by MkX Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 21, 2012 Share Posted March 21, 2012 On 3/21/2012 at 4:32 AM, MkX said: I'm confused. Civicferio started the thread and but prvnrox haven't given much details about this problem. @prvnrox would you mind giving more details of the problem you have. I noticed you have already bought new TB. Did you change it? What RPM range it fluctuate? Does it change only at IDLE or when you driving too? If you can give us more details, we will be able to share some knowledge. Because I went through this IACV and TPS issue for quite some time and solved the problem with changing TB. Also your TPS can malfunction without CEL giving any indication. Because it works in voltage range and error code only appear when it goes below the threshold AFAIK. yes bro the exact case is when it is on idle,there is a drop in the rpm to 100-200.when i drive it doesnt fluctuate.but anway when its at parking also some times it continuously goes up n down 1000-1500 range.some times (mostly in the cold start) when i accelerate the car accelerates with a jerk (stays t about 500 and then suddenly comes upto around 2000).when i give the pedal smoothly it car jerks in throttle.but this doesnt happen always.drop of the idle RPM happens almost every time (despite cold or warm). Then mech at stafford said in hondas if there's any fault of those sensors,the CEL comes up.i dunno though since some of the experts here are saying its not the case always..is there anyway i can check it?? but um not soo good with this mech stuff! :S guys i also need to ask you.Did u guys notice any increment in fuel consumption when u had this problem??mine is an auto multimatic.does around7.5-8 kmpl in the city.11-12 outstation. Quote Link to comment Share on other sites More sharing options...
MkX Posted March 22, 2012 Share Posted March 22, 2012 (edited) Ok, assuming your car is EK3-Vi, I must say your fuel efficiency is very much low compare to others. I’ve being using same car (manual) for last 3 years. I hardly get anything below 11/12 Kmpl with A/C on, unless you use it at SPORTS mode (in Multimatic) all the time. When I start in the morning my RPM goes up to 1000 – 1500 and after driving for a while it reduces to normal level. However when I use A/C and the vehicle come in to idle RPM drops to 300/500 range. Most people with same car told me they have the same issue but not solved. Cleaning IACV will not rectify this problem because either it’s electric motor inside or the spring that something to do with this. Best thing is get adjust to this if possible. RPM fluctuation issue is different to what I mentioned above. It is when you keep the car in idle (or even in move) RPM goes up and down continuously without a pause. So you can see your RPM gauge movement between 750/500 to 2000/2500 range. Reading your post gives me the idea that you don’t have this problem but the previous. The jerk you mentioned here is most likely a problem with the Multimatic gear box. This problem occurs with wrong ATF or when gear box not maintained properly. Check youtube, you’ll see so many videos of the RPM fluctuation due to TPS problem without CEL giving any indication. Edited March 22, 2012 by MkX Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 22, 2012 Share Posted March 22, 2012 well mine is not a manual.its an auto.but still i thought it should do 9-10kmpl in da city with A/C.no i dont think its a gear box issue.because the gears change pretty well and i use CVTF.my RPM drops even below 500 almost to 100 or below and then the jerk comes.in the cold start the acceleration prob comes.so they said its the IACV. i was thinking about both these jerk issues and the fuel effieciency issues.so i asked the mech check my oxygen sensor and then also he said if the oxygen sensor is faulty CEL will come up.i dunno :S Quote Link to comment Share on other sites More sharing options...
MkX Posted March 27, 2012 Share Posted March 27, 2012 Is your problem solved? Mine also some times drop below 500 too but not all the time. What is the acceleration issue you mentioned here? Is it low pulling power whenyou accelerate or RPM drops suddenly even when you press the accelerate peda? Quote Link to comment Share on other sites More sharing options...
prvnrox Posted March 28, 2012 Share Posted March 28, 2012 not yet! couldnt change the tb yet! no machan pulling power is ok.some times it pulls step by step in the cold start. Quote Link to comment Share on other sites More sharing options...
civicferio Posted July 14, 2012 Author Share Posted July 14, 2012 On 3/28/2012 at 11:09 AM, prvnrox said: not yet! couldnt change the tb yet! no machan pulling power is ok.some times it pulls step by step in the cold start. Hi prvnrox, Have you changed IACV. any improvement? Thanks Quote Link to comment Share on other sites More sharing options...
prvnrox Posted July 14, 2012 Share Posted July 14, 2012 i tried a new (recon) IACV but dint work.its hell of a headache :S these days um broke so couldnt spend money on the car.will let u know once i fix it.um going to waruna and see.so far i've shown it to Mahesh,Ajith and also the BOSCH service center Quote Link to comment Share on other sites More sharing options...
