April 7, 201214 yr You can continue to pump Octane 90 and many Sri Lankans do. But keep in mind the engine is not designed for that and after some time your engine deposits will be higher than normal for the same amount of mileage. You will run into preignition knocks due to that. And I would like yourself explaining on what basis that RON90 is ok for an engine designed for RON91 and above. And mind you in JP, MY Sing and many other countries where the 1NZ-FE engine is used, those pumps do not carry Octane 90. I use xtra premium Euro3. cheaper than 95
April 7, 201214 yr Author I use xtra premium Euro3. cheaper than 95 then best thing is not to use octane 90. ok then how about 93 vs 95. what is ur recommendation pls
April 10, 201214 yr Wtf are you talking about? That's not a brochure, it's the user manual I got with car, and it's printed in Thailand. There are no Japanese manuals for the Vios because it was never sold in Japan. Get your facts in order, else you'll only be spewing out useless disinformation. I'm sorry for the manufacture country i missed. but my facts still stands. you're correct vios made in Thailand and your user manual printed in Thailand becouse it mainly targeted Thai road conditions and weather, So its couldn't apply to Sri Lanka. Thai road conditions and Weather not same as SL. So figuers in that manual not correct in SL. Don't forget vios is a Thailand base domestic car.
April 10, 201214 yr I'm sorry for the manufacture country i missed. but my facts still stands. you're correct vios made in Thailand and your user manual printed in Thailand becouse it mainly targeted Thai road conditions and weather, So its couldn't apply to Sri Lanka. Thai road conditions and Weather not same as SL. So figuers in that manual not correct in SL. Don't forget vios is a Thailand base domestic car. The weather and road conditions in Thailand are more similar to Sri Lanka than you think.
April 14, 201214 yr I can probably make copies of mine. If you guys know of a place that can properly photocopy and bind pages (odd dimensions) like what I took photos of earlier let me know.
April 16, 201214 yr one more advice, get your AC fully serviced at least once a year. I was a victim of busted evaporator (2 times). Replacement of the evaporator is a very tedious (unpleasent) repair to see.
April 16, 201214 yr I can probably make copies of mine. If you guys know of a place that can properly photocopy and bind pages (odd dimensions) like what I took photos of earlier let me know. Are you reffering the "user manual"
April 16, 201214 yr one more advice, get your AC fully serviced at least once a year. I was a victim of busted evaporator (2 times). Replacement of the evaporator is a very tedious (unpleasent) repair to see. Probably your Vios did not come with a cabin filter. That reduces the lifetime of the evaporator. It is strange that some Vios cars do not have the factory fitted cabin air filter. Edited April 16, 201214 yr by Az
April 16, 201214 yr Probably your Vios did not come with a cabin filter. That reduces the lifetime of the evaporator. It is strange that some Vios cars do not have the factory fitted cabin air filter. Nop there is no such a filter in the evaporator assembly. Are you sure, that some vios cars came with that filter.
April 16, 201214 yr Nop there is no such a filter in the evaporator assembly. Are you sure, that some vios cars came with that filter. Yes, my Vios, a 2004 model has the cabin filter, while my brother's car, a 2005 Vios does not have the cabin filter. The evaporator on that car too was replaced a few months back while mine still has the original evaporator, and I just have to change the filter about once a year. Yeah, it was a very messy replacement. The whole dashboard assembly had to be taken apart.
April 16, 201214 yr Yes, my Vios, a 2004 model has the cabin filter, while my brother's car, a 2005 Vios does not have the cabin filter. The evaporator on that car too was replaced a few months back while mine still has the original evaporator, and I just have to change the filter about once a year. Yeah, it was a very messy replacement. The whole dashboard assembly had to be taken apart. Oh, Mine also a 2005 one. Regarding the replacement,,,Did your brother found the original evaporator or replaced with a Malaysian one in the market. I can remeber last time (2yrs ago), the repairing guy used the non geniuine one. Now it has failed agin. One more thing...is it an inherent characteristic that the AC system of vios is not powerful....
April 16, 201214 yr How do you define not powerful? I always set the temp on the coldest, but fan speed on minimum and thats good for me on most days except the sunniest. Sometimes in the evening I actually turn the temperature up a little because things are too chilly. I'm also known as the Polar Bear (hima walaha) in my office because I really like the cold. So yeah, the A/C in the Vios is more than capable of even keeping me cool. I did however get the A/C serviced right after I bought the car. They cleaned the filter and removed some scraps of paper from the ducting. Edited April 16, 201214 yr by terrabytetango
April 16, 201214 yr Oh, Mine also a 2005 one. Regarding the replacement,,,Did your brother found the original evaporator or replaced with a Malaysian one in the market. I can remeber last time (2yrs ago), the repairing guy used the non geniuine one. Now it has failed agin. One more thing...is it an inherent characteristic that the AC system of vios is not powerful.... I think it was replaced with a non-genuine evaporator because the whole repair cost only about 22K. The original brand new Toyota evaporator for the Vios is insanely expensive. I don't think the Vios A/C is inherently less powerful since I get excellent cooling even during the hottest times of the day.
April 16, 201214 yr How do you define not powerful? I always set the temp on the coldest, but fan speed on minimum and thats good for me on most days except the sunniest. Sometimes in the evening I actually turn the temperature up a little because things are too chilly. I'm also known as the Polar Bear (hima walaha) in my office because I really like the cold. So yeah, the A/C in the Vios is more than capable of even keeping me cool. I did however get the A/C serviced right after I bought the car. They cleaned the filter and removed some scraps of paper from the ducting. On sunny days, the cooling is not adequate especially for people at the back seats, thats why i thought it is not powerful. We have a small buddy van, compared to that the the air is not cool in the Vios. Probably, something wrong with the AC system. Also, the compressor become really noisy some months back. The AC servicing guy charged some oil and then the noise decreased bit.
April 18, 201214 yr Author IS MAGGCITY is a good place for AC cleanup ??? tell me that Vios has Heater or not ?? i cant find it in my vios
April 18, 201214 yr Author and also pls update Us how to use AC correctly. is it good to on and off it frequently. or anything to do special ? pls reply
April 18, 201214 yr and also pls update Us how to use AC correctly. is it good to on and off it frequently. or anything to do special ? pls reply Friend, you are asking too many basic questions. If you really need I would answer, but for these simple stuff do a search please. www.google.com is a good place to start with. I am telling you in good faith, do research and learn, you will be bit happier than just asking from everyone.
