Hi all
is anybody know how to adjust/correct the air level on the EK3 exi
Sira
guess your asking how to change the fuel + air mixture ?
if its a cab one, u can do that with the jets it has... air + fule
if its EFI, the ECU does the job with sensors, (02, Temp etc) but you can re-program the ECU with the right tools and chips :)
but keep in mind, this things can go off, if you have dirty air cleaner. blocked injectors. bad O2 sensors etc
Kalinga
Nop this is Brandnew one which made 1998 and dose not have O2 sensor , it got 3 stage catalitic convertoer( i guess)
who you prefer to check the ECU
sira
