sam333
Hi all,
does anybody knw where is corolla se saloon/ se limited original car antena got fixed??? I already searched in many & figured, it's not came with power antena, rear roof mounted antena or side antena(as xe saloon/ xe limited). So, where it is fixed...????
Thank you.
  On 6/13/2012 at 10:01 PM, sam333 said:
Hi all,
Thank you.
original antenna is coming to rear windscreen. see carefully little copper line on the rear windscreen. there is heater, and top lines are the antenna. see carefully.
Edited by Nilantha
  • Like 3
  On 6/14/2012 at 4:39 PM, hasmax said:
i have a L grade SE Saloon sprinter. The antenna is located on the dashboard in drivers side corner, a small rounded plate like thing with about 5 cm in diameter.
it may not the radio antenna. it is should be satalite receiver (antenna) of the GPS system. is this singapore used sprinter?
Is that EE111 Sprinter?
http://web-cache.stream.ne.jp/www09/toyota-catalog/pdf/sprinter-3/sprinter-3_199804.pdf
Thanx..... Yes it is there.... :grinning-smiley-003:
If there is a tinted rear windscreen, Can it make problem for radio signals???? :blush:
ahhhh... prv owner told me it is antenna. another damn lie of him then. well i am not sure where it was used.
