I have a Toyota Carina AT192(1995) car. It has run 130000km. When I'm running the car, some times it is blinking the check engine bulb. but it is not always coming on. when the bulb comes on, car is running slowly. once i checked with a garage. they scanned and said there is a problem with the oxygen sensor and instructed me to do a engine tune up. they said u might have to change the oxygen sensor then.
But I connected the TE1 and E1 in the diagnosis and check the check engine bulb. it is blinking normally as recommended.
and other problem is i need to put engine oil time to time. i think engine oil is burned more than normal condition. i informed this to the garage and they said you have to change the rings set first and then do the the engine tune up. they said without changing the rings set, no point of doing the engine tune up for that check engine problem. for this issue, my friend (mechanic) said just put new PCV valve first and check still this engine oil issue is there.
please give me the correct advise for this issue. because I'm confused with this different advises of different people.if i have to change the rings set and do the engine tune up with genuine parts, what will be the cost like? what is the suitable place to check this both issue?
So once again I got bored with the car, and I thought of selling it in the beginning of next year and buy a Porsche 997 Cabrio or a Mercecedes SL R231 Cabrio
thara123
Hi All,
thanks
Edited by thara12311 answers to this question
