Pajero Posted August 23, 2012 Posted August 23, 2012 I have a Mitsubishi Pajero exceed 1989 autogear jeep. Normally i get 6,7 kmpl in city limit. Is that fair enough for a pejero ? If not what is the problem for that ? please be kind to have your comments here. Quote
fuzzo Posted August 23, 2012 Posted August 23, 2012 7 is very good amount.. ive never been able to get more than 5.5 1 Quote
edsal Posted August 23, 2012 Posted August 23, 2012 Either you are a very good driver or very lucky because usually fuel range between 3 to 5 Kmpl. 1 Quote
Pajero Posted August 23, 2012 Author Posted August 23, 2012 7 is very good amount.. ive never been able to get more than 5.5 Either you are a very good driver or very lucky because usually fuel range between 3 to 5 Kmpl. well im amazed by the replies you have given bcause most of the people im dealing with are telling that palathsabha pajeroes are good in fuel consumption around 9-10 kmpl can get in a manual gear. Quote
jdnet Posted August 23, 2012 Posted August 23, 2012 well im amazed by the replies you have given bcause most of the people im dealing with are telling that palathsabha pajeroes are good in fuel consumption around 9-10 kmpl can get in a manual gear. Is it hard to imagine those people lying to you? 1 Quote
priyanka Posted August 23, 2012 Posted August 23, 2012 I have a Mitsubishi Pajero exceed 1989 autogear jeep. Normally i get 6,7 kmpl in city limit. Is that fair enough for a pejero ? If not what is the problem for that ? please be kind to have your comments here. dont know about the auto........... but i was able able get 8+ km/l in city with my previous jeep, which was a manual one i think it is because of your driving style probably............ 1 Quote
priyanka Posted August 23, 2012 Posted August 23, 2012 Either you are a very good driver or very lucky because usually fuel range between 3 to 5 Kmpl. cant be.............. 1 Quote
harshansenadhir Posted August 24, 2012 Posted August 24, 2012 If it's a manual gear, then an experienced driver can squeeze out impressive mileage figures with it's turbo-charged engine, either 2.5 or 2.8 with lost of torque in the lower end. You can pull away in higher gears and shift quickly to 5th and "can manage" to save lot of fuel. in case of OP, since it's automatic, I feel the figures are about right. 1 Quote
Clark's son Posted August 24, 2012 Posted August 24, 2012 (edited) I have a Mitsubishi Pajero exceed 1989 autogear jeep. Normally i get 6,7 kmpl in city limit. Is that fair enough for a pejero ? If not what is the problem for that ? please be kind to have your comments here. For the auto this may be correct so have no fear mate Throw in a bottle of injector cleaner of a reputed brand if you haven't done it recently, (and don't use the crappy ones). A manual would do around 8kmpl in short runs and with the low ratio gear box (even in high range) it can be put into top gear even below 50kmph, and that kind of driving will take the figure close to 10kmpl Edited August 24, 2012 by Clark's son 1 Quote
Pajero Posted August 26, 2012 Author Posted August 26, 2012 dont know about the auto........... but i was able able get 8+ km/l in city with my previous jeep, which was a manual one i think it is because of your driving style probably............ If it's a manual gear, then an experienced driver can squeeze out impressive mileage figures with it's turbo-charged engine, either 2.5 or 2.8 with lost of torque in the lower end. You can pull away in higher gears and shift quickly to 5th and "can manage" to save lot of fuel. in case of OP, since it's automatic, I feel the figures are about right. For the auto this may be correct so have no fear mate Throw in a bottle of injector cleaner of a reputed brand if you haven't done it recently, (and don't use the crappy ones). A manual would do around 8kmpl in short runs and with the low ratio gear box (even in high range) it can be put into top gear even below 50kmph, and that kind of driving will take the figure close to 10kmpl well thanks for the replies guys i appreciate you Quote
