alpha17 Posted September 19, 2012 Share Posted September 19, 2012 A*to w*rld suggested me to change the shocks of my 121.what is the best option that i can go for?will the brand new imported 121's shocks do better on sl roads than the jdm shocks?specially comfortable than jdm shocks? Quote Link to comment Share on other sites More sharing options...
jdnet Posted September 19, 2012 Share Posted September 19, 2012 Go with KYB. Seriously how many threads about shocks do we need? Quote Link to comment Share on other sites More sharing options...
alpha17 Posted September 19, 2012 Author Share Posted September 19, 2012 Are they better than brand new imported 121's shock absorbers?are they comfortable,and durable?i prefer comfortability and durability most.are they better than genuine toyota ones? Quote Link to comment Share on other sites More sharing options...
The Don Posted September 19, 2012 Share Posted September 19, 2012 Are they better than brand new imported 121's shock absorbers?are they comfortable,and durable?i prefer comfortability and durability most.are they better than genuine toyota ones? DhoRk, you need to start using the search feature a bit more because this has got discussed recently in great detail. What you need to understand is Toyota does not make shock absorbers. In Japanese vehicles nearly all of the shock absorbers used are either made by Tokico or KYB so they are the original equipment makers. So even a genuine Toyota shock will be made by one of them. The only problem here is there are many compatible shocks for your car by both these manufacturers as there many variants of the 121 made for different markets. The more durable shocks tend to be a bit harder, and the softer more comfortable shocks tend to be less durable. Quote Link to comment Share on other sites More sharing options...
SimpleAuto Posted September 19, 2012 Share Posted September 19, 2012 DhoRk, you need to start using the search feature a bit more because this has got discussed recently in great detail. What you need to understand is Toyota does not make shock absorbers. In Japanese vehicles nearly all of the shock absorbers used are either made by Tokico or KYB so they are the original equipment makers. So even a genuine Toyota shock will be made by one of them. The only problem here is there are many compatible shocks for your car by both these manufacturers as there many variants of the 121 made for different markets. The more durable shocks tend to be a bit harder, and the softer more comfortable shocks tend to be less durable. KYB is the OEM for Toyota, so the best option.... Quote Link to comment Share on other sites More sharing options...
alpha17 Posted September 19, 2012 Author Share Posted September 19, 2012 For comfortability what is the best option that i can go for? Quote Link to comment Share on other sites More sharing options...
SimpleAuto Posted September 20, 2012 Share Posted September 20, 2012 For comfortability what is the best option that i can go for? It is KYB for Toyota; but for Honda,it might be Tokico Quote Link to comment Share on other sites More sharing options...
The Don Posted September 20, 2012 Share Posted September 20, 2012 It is KYB for Toyota; but for Honda,it might be Tokico Unfortunately the answer is not as straight forward, because KYB will have a number of compatible shocks for the 121, as there are different variants offered with different models for different markets. It might be useful to check with the KYB agent if they could tell you what KYB models/ part numbers they have available and cross check it with other sources to figure out which version is the genuine item for the domestic model 121 because that would be the most comfortable. You also need to figure out if the original shocks in your car is gas or hydraulic. If it's hydraulic you should stick to hydraulic if comfort is a priority because the equivalent gas shocks will be firmer (but also more durable). If you originally have gas shocks this is not an issue because spring tension would be calibrated to suite gas shocks. Quote Link to comment Share on other sites More sharing options...
alpha17 Posted September 20, 2012 Author Share Posted September 20, 2012 That means jdm is comfortable than the brand new imported model? Quote Link to comment Share on other sites More sharing options...
The Don Posted September 21, 2012 Share Posted September 21, 2012 That means jdm is comfortable than the brand new imported model? Usually, if its the same fitment. The brand new imported models tend to have more rugged suspension when intended to countries like Sri Lanka. That makes it more durable and fare better in our pot hole ridden roads. The problem is sometimes the part itself is slightly different so you need to check whether it fits and this does not apply to every vehicle as manufacturers have different strategies. Quote Link to comment Share on other sites More sharing options...
alpha17 Posted September 21, 2012 Author Share Posted September 21, 2012 I checked and mine and has gas shocks.i'm pretty not satisfied to use KYB as my uncle changed his swift's using KYB(jeep model) and i dont feel a difference at all! Quote Link to comment Share on other sites More sharing options...
SimpleAuto Posted September 21, 2012 Share Posted September 21, 2012 I checked and mine and has gas shocks.i'm pretty not satisfied to use KYB as my uncle changed his swift's using KYB(jeep model) and i dont feel a difference at all! Make sure you pressurize it properly.......thats the main reason for the ride to be uncomfortable... Quote Link to comment Share on other sites More sharing options...
harshansenadhir Posted September 21, 2012 Share Posted September 21, 2012 I pretty much doubt that you can gain / improve comfort factor by changing shocks or replacing shocks. However if you need to compromise stability and have a soft ride, go for oil pressured shocks instead of gas cartridge type. Quote Link to comment Share on other sites More sharing options...
kalana Posted September 21, 2012 Share Posted September 21, 2012 my swift gets uncomfortably low ground clearance with 4 people.And I feel little vibration on the steering wheel when driving on wattala to peliyagoda road.(this part of the road has a little bit rough carpet i guess). any guesses guys ? Quote Link to comment Share on other sites More sharing options...
The Don Posted September 21, 2012 Share Posted September 21, 2012 my swift gets uncomfortably low ground clearance with 4 people.And I feel little vibration on the steering wheel when driving on wattala to peliyagoda road.(this part of the road has a little bit rough carpet i guess). any guesses guys ? Wheel alignment, suspension geometry, bushes or wheel balancing is probably your problem with regards to the vibration. The ground clearance, well that is just the design of the car. Quote Link to comment Share on other sites More sharing options...
Blitz Posted January 8, 2013 Share Posted January 8, 2013 326 ppi. Total the size and excess weight really feel excellent inside the palm of one's hand sporting its trademark black colour with red highlights, however it could really feel a tad hefty or bulky for some customers with smaller sized hands. The HTC Sensation XE packs a blistering dual-core Qualcomm Snapdragon processor working at 1.5GHz, most likely creating this the quickest beats by dre uk dual-core smartphone released to date, ahead of a number of other individuals running at one.2GHz such as the HTC Evo 3D and Samsung Galaxy S II. Working on the most recent Android OS v2.3.four (Gingerbread), it packs the typical array of features due to its proprietary HTC Sense UI, like multi-touch delicate controls, accelerometer, proximity and gyro sensors. Speed is certainly a hallmark for this smartphone, although storage will not be its strongest stage, providing a mere 4GB coupled with 768MB RAM, accompanied by an expandable microSD card slot that supports up to an added 32GB. Also armed that has a eight megapixel camera, a VGA front-facing camera, and complete HD 1080p video capturing at 30fps, the HTC Sensation XE doesn't fall quick in this arena also, trying to keep up to par using the just-released iPhone 4S. Download speeds are also swift going at a trend-setting 14.4Mbps on HSDPA (three.5G), and together with the typical set of connectivity alternatives such as Bluetooth 3.0, microUSB beats by dre cheap two.0, and Wi-Fi 802.11 b/g/n, battery capability has also been boosted which has a larger 1730mAh battery,.Including multi-touch delicate controls, accelerometer, proximity and gyro sensors. Speed is unquestionably a hallmark for this smartphone, however storage is not its strongest point, providing a mere 4GB coupled with 768MB RAM, accompanied by an expandable microSD card slot that supports as much as an supplemental 32GB. Also armed having a eight megapixel camera, a VGA front-facing camera, and total HD 1080p video capturing at 30fps, the HTC Sensation XE will not fall short in this arena as well, keeping up to par together with the just-released iPhone 4S. Download speeds are also quick going at a trend-setting 14.4Mbps on HSDPA (3.5G), and in addition to the regular set of connectivity solutions such as Bluetooth 3.0, microUSB 2.0, and Wi-Fi 802.11 b/g/n, battery capacity has also been boosted which has a more substantial 1730mAh beats by dre cheap battery, which HTC claims to offer a speak time of 7.five hours. Saving the ideal feature for last here, the outstanding function on the HTC Sensation XE is definitely likely to be its audio, because of HTC's teaming cheap beats by dre up with Beats by Dr Dre. The popular headphones under the Beats line here are known for their significant booming bass, so including inside the Beats audio impact function that could be turned on and off using the bundled Beats headphones surely provides a sensational audio practical experience. The only snag right here would naturally be you would really need to use Beats headphones and not other individuals to appreciate this audio. machan this is autolanka. & the thread is about Shock Absorbers.. not about HTC sensations.. Quote Link to comment Share on other sites More sharing options...
fonfe Posted January 8, 2013 Share Posted January 8, 2013 It's very simple, as a rule of thumb: Harder spring and shock combination gives a firmer more responsive drive. - At the cost of ride comfort. Softer spring and shock combination gives a softer smoother ride but at the cost of less firm handling characteristics. Just changing shocks on their own will have little effect on ride comfort.......the spring also requires changing to match. Ultimate best, of both worlds in my opinion is air springs but these are very costly. Or adjustable "coil over" suspension where the dampening rate and ride height can be simply adjusted using a C spanner and an adjuster knob on the top or bottom of the shock absorber. - serious overkill for a non competition vehicle but if you have the money it's your best bet. Kalana - you can fit stiffer springs this will stop your ground clearance being so low when fully loaded. It will make the ride harder though and the car will sit higher when not fully loaded. A cheaper and simple method all thought not "politically correct" in the car world yet still done by many with extreme lowered cars is to fit caravan supporters to the rear springs. This stops the spring coils from compressing past a certain point. Take about 10 mins to fit. They look like this: http://www.towsure.com/product/Towing_Spring_Assisters_prod Quote Link to comment Share on other sites More sharing options...
