Engine Light - P0444 & P0422
Hi all,
I have an accent 2000 1500cc manual car. Three weeks back check engine indication appeared but nothing was unusual.But i wanted to get it scanned and after scanning (error codes were P0444 & P0422) got to know that It was someting to do with the purge valve, which was then cleaned by a mechanic at a leading gurage in nugegoda. After doing everything light didnt come up for about another 100km+.Again the light appeared after about 100km,still nothing was unusual. when the car was taken to the same gurage a different mechanic without scanning cleaned the Air flow sensor and erased the code by removing the battery terminals. This incident happened a week ago. Apparently on today again the light appeared after about another 150-160km. Could anyone advise what could be done to rectify this issue. (still nothing is unusual on the car).
7 answers to this question
dear did you scan it from company, as i have one exp for my kia car i scanned some places and according to the error code did some works but the problem remained same then finally did it company and found out the exact reason and now its ok.
