Heat Meter Goes Up When In Traffic
4DR5
Hi experts,
i'm having a 2006 maruti zen LXi model car. Since of late, i have noticed that the heater meter goes up when in traffic. it comes back to the normal middle level position when i start driving again.
there is no water leak from the radiator, there is enough water in the reserve...etc.
can anyone advise.
4dr5
13 answers to this question
sometime's the brush's of the fan wear out and can work one moment and not work the next. Check the fan a couple of times (especially when you realize the engine eating up)
At least the symptoms point to a faulty fan. To elaborate; when the car is not moving there is no cool air blowing into the radiator hence the rise in temp. And when you start driving the breeze that hits the radiator will start to cool the system again..
Heat gauge moving up slightly when vehicle is standstill can be noticed, if the thermostat has been removed.
1. Is it moving passing the middle point?
2. Is it happening while a/c switched on or off?
3. If answer for no 2 is yes, does it happen in the day time only?
4. Does the same happens if you run and park the vehicle in your driveway ?
Do you mean the thermostatic valve or the fan thermostat?
Thermostat Valve obviously. If the valve has been removed, coolant will always recirculate through rad. When cruising, heat exchange would continuously happen and would bring the gauge down from middle point (coolant temp lower than operating temp)
If the vehicle stops or travels in bumper to bumper, then the temp would rise upto the point where temp sender unit sends the signal to operate fans.
So in this case, need to identify how significant this "rise" of the gauge.
  On 9/28/2012 at 8:07 AM, 4DR5 said:
Hi experts,
can anyone advise.
4dr5
4dr5,
Try the radiator core cleaning out side with high preassure water jet.
Sylvi wijesinghe.
Edited by Sylvi
  On 9/28/2012 at 11:48 PM, Sylvi said:
4dr5,
Sylvi wijesinghe.
I would give this advise to relatively old vehicles without a/c condensers infront of the radiator and also if the radiator got stiff copper fins. Most a/c condensers and radiators nowadays got tiny alluminium fins.
High pressure washer jet might bend these fins creating more resistance to air flaw. Been there done that, I know this isn't a good idea :)
'harshansenadhir',
I am not try to dispute your theory behind same.
I have noticed many A/C Repair centers hold high pressure water jet to the A/C condenser when they get blocked .
I had a Nissan van when I had low cooling they did that in Dehiwala one repair center, the problem was OK after that..
thanks for the replies,
Is it moving passing the middle point? yes
2. Is it happening while a/c switched on or off? it happens with A/C on as well as off
3. If answer for no 2 is yes, does it happen in the day time only? both day and night
4. Does the same happens if you run and park the vehicle in your driveway ? yes
i also checked and saw that the radiator fan was working properly. I have already flush the radiator but still the problem exists.
Thnaks
4DR5
Thnaks
4DR5
Ok, seems this is only related to cooling system. no inter-relationship with the A/C system.
Can you carryout following steps from a cold start.
1.Open the radiator cap and check whether there's coolant in visinity. if not add coolant / water
2. Start the engine (keep A/C switched off)
3. Watch how the temp gague rise up. Also watch for radiator fans.
tell us following,
1.How long does it takes for the gauge to reach middle point. ?
2. does fan engages as gauge reaches middle point?
3. if not at which point fans do kick in ?
4 does water spurts out radiator cap openning before / after fans start running?
