Hi Experts,
Appreciate your valuable responses in advance. I'm in the market, seeking a Hydraulic Jack for a Kia Sorento 2012 model which is weighed around 3900Kg. Is there any specific brands to be looked in to? How much will it cost and any good place to shop for these?
Edited by ModX
ModX,
You will have to buy a Hydraulic operated Jack with lifting capacity of 2 tons minimum.
If you have a passenger load in your vehicle if you want to change a tire without requesting them not to get down.
Then any jack has to go in for a capacity above 3 Tons. Be OK.
There a plenty of brands available in Panchikawatte.
It all depends how much you want to spend for Jack.
Sylvi Wijesinghe.
2 comments/questions on Sylvi's post:
1- For starters, I think its pretty dam dangerous to change a tyre of a vehicle while people are still in it considering a sudden movement can send everything tumbling down on your foot.
2- If no passengers, its a 2 ton jack, and with passengers its 3? Sorento being a 7 seater at most, and you being the driver you're looking at 6 people in the vehicle.. so 166kg per passenger????? Either you're bad at math or you have one fat bunch of family/friends.
Total load of the vehicle will distributed symmetrically over the four wheels. There fore it is not required to go for a 03 Ton or 02 Ton jack since you will be replacing one tire at a time using the jack. something around 1.5 Ton will do the job
Hi Experts,
Yep, 1.5 or 2 ton will do it, but didn't it come with a jack or you lost it?
i had a 2 ton on my previous truck one of the best investment i made considering the stock one was a bugger to use..think i spent about 3k on it back in 2009
XBeat, you are not correct (and that goes for Kushan too). While a 1.5Ton might be enough, the weight is not symmetrically distributed along the 3 wheels. When a vehicle is not loaded on a vehicle with the engine in the front, there is more weight on the front wheels than the back. This is why you pressurize the front wheels more than the back. Now when the vehicle is loaded the weight might shift and depending on the design of the vehicle you might get more weight on the back wheels.
So while as you don't need a jack which can handle the entire weight of the car, you can't depend on symmetric weight distribution either. The weight rating on the original jack supplied with the vehicle is a good indication of what a replacement jack will need to hold.
well.. I agreed only on the point of 1.5 ton, yes it is not symmetrical as you explained.
Members,
Opinion differs from one person to another.
I have changed tires with the load and without the load take for instance when a lorry is loaded if you have to change a tire.
Do the driver and the cleaner have to unload the load first and change the tire and reload. there are safety precautions for all above.
I have seen with passengers in the bus. Driver and the conductor change Tires on the road.
I gave safe capacity of the Jack for easy handling. when there is a load it is difficult to operate low tonnage jack.
That is the main reason I suggested to use a higher capacity jack.
Sylvi Wijesinghe.
Sylvi Wijesinghe.
What he said was sudden movement inside can cause an issue. A loaded lorry does not move by itself, while what bus drivers/conductors do is totally different story :)
Members,
Sylvi Wijesinghe.
I dont think logs or bags of cement would suddenly reach to the front the change the radio channel or lean out the window to ask you "machang tire eka hari da?"..
Well, its upto you if you want to use a bus-driver as a benchmark for safely operating a vehicle.. But I dont deny that people still do MANY stupid things .... For example things like changing tyres while there are people in the car; changing the bulbs in their signal lights to blue; or even purposely disconnecting the fanbelt of the vehicle when driving in the rain... you be the judge ;)
Edited by Watchman
Why disconnect the fan belt?
