After an accident, there are people those who erase or do changes to hide the airbag check light (shorting it with the battery light).
By looking at the blinking of the airbag check light only, hope we can identified it is cheated or real.
Please share your expertise specially on FB14,FB15, Corolla 110, tercel EL51, 121, etc.
Air Bags are not serviceable items. In case of an accident you have to remove them completely or replace them. If not messed up, the self test at the start up is a reliable diagnostic. If you are in doubt can get the system scanned; the results will show that the airbag system is at fault.
Guys, if a Chinese ribbon has been used in an aftermarket multi functionality installation, that can also give an air bag sensor issue. However, it should be known that the air bag sensors also have around 4 ppm error.
