Toyota Axio 2011 - Maximum Alloy Wheel Size
Hi
the car is Toyota Axio 2011 model.as i heard from few people in the industry they sed maximum alloywheel size is 17 inch....just need to know the facts about it....cuz some say dont put it cuz roads are not tat good....but when i ask from the rim shop today they sed nothing to worry...
the original tire set has this - 185/65 R15
note - there was a used set contains 17inch wheels and low profile tire set....just ok the tires are as they look and wheels have scratches and chips....the wheels can be painted isnt it?
thanks.
6 answers to this question
honestly i dont know how to use it sir
You select your current tyre size from the top. Then on the bottom you select the wheel diamater (17) and then play around with the tyre profiles so that you get the least diameter difference ( less than 4% zero if possible).
Usually a profile less than 15 is probably a little bit uncomfortable on Sri Lankan roads. But the following tyre sizes seem suitable.
205/50 R17
195/50 R17
195/55 R17
185/55 R17
According to the site anything between -2.5% to +2.5% is OK.
Since you are going from 185mm to 215mm maybe you should check if the tyre isn't rubbing against car when taking a full turn.
