What should be the engine rev for an automatic gear box to shift gear?
Ahould it go up to 4k rpm to shift?
Thanks,
Thanks,
depends on the engine,fuel type,car make , model , the way you accelerate, and various factors, give more detail so people can understand what you ask ?
Edited by chan5
Car: Paj IO
Engine: GDI
Fuel: Petrol
No.Of.Gears: 4
Acceleration concerned: A sudden kick donw (The down shift/kick down happens very well, it's the shift to the next gear i'm concerned with)
depends on car to car and how heavy or light footed you are
it usually changes around 2000-2500 RPM
if you floor it around 3000 - 3000+
if your light footed even at 1500
Try to control your right foot mate and you'd be fine.If you are new to this car, take it to an empty parking lot or a road out in nowhere and experiment with it to get a feel/understanding about how it operates under different conditions. Once you get the right feel for it, you'd be able to alter the gear shift points to whatever the rpm you want by varying the throttle position.
Cheers.
Cheers.
Well he has a gdi turbo. That should explain the high revs when up-shifting.
