Replacing Broken Center Antenna In Chevrolet Cruze
Hello Experts,
Antenna in my Chevrolet Cruze is broken in to two parts.
Will I be able to replace it? I think its same as in Suzuki Swift or Suzuki Ignis.
Thanks.
Good for you, you got at leaset one part available.
Mine was removed by some other owner of the antenna.
What I did was installed a small internal antenna sticking on the windshield to make the radio workable.
Easthetics due to missing antenna not solved though.
If the base and the thread are intact you should be able to fit a new one.
My wife's Demio antenna was broken and managed to find one from Delkanda area for 1200 Rs. (Not exactly same as original but thread is ok and served the purpose)
  • Author
Where did you get windshield antenna sticker? ebay? Is it something like below? Really appreciate your help on this :)
I think they are in intact I should go to Delkanda and see. May be I could find an antenna which fit to the base. thanks guys :)
  • Author
Well you can probably find the original if you wanted to.
Yeah i should check at Delkanda. What I am not sure is that will it fit with the current base?
If you check UK ebay, there are plenty of replacements for the side antenna version as it came in the Ignis. Not sure if the Ignis ever sported the center antenna. But its a popular car, so you should be able to find a replacement. I think the center antenna doesn't go down does it?
They all share the same base and thread I think, so it shouldn't be an issue.
  • Author
I also think that Ignis doesn't come with center antenna. Yes it doesn't go down. If I can't find a good replacement in Delkanda I'll look in to getting down it from ebay.
Great! Glad to here :)
