My car is Nissan N16ex singapore imported model(Some are Say N17), Auto 1.6cc
Recently my car had an accident which was hit by another car to left back side. It was take more than one and half month to repair the car and , when i went to take the car after repairing the instrument panel gauges are not working. ( Those were OK after happening the accident) The ABS motor is continuously running with ABS light is ON.
The guy in the repair center disconnected the ABS motor fuse & Start the engine & go for a test ride. The ABS light was ON. They said there is a problem with ABS motor & have to replace it.
In the instrument panel no gauges were working Including ODO/TRIP meter & Clock.Only the lights are working. i.e. Air bag check/ Oil/ Battery/ signal etc. except Engine check light. It does not even switch on. Auto gear indicator lights are also not functioning One of the guy in the repair center open the cluster panel & check & found that one smoothing condenser is blasted. After that they have replaced it and there was no success.
ABS motor was also replaced and the continually running ABS motor problem was solved, But ABS option is not functioning. They said they need to replace Instrument cluster as well.
My questions are
1. Where can i find a instrument cluster for this model?. I have searched in many places and couldn't find this model.( 220 Kmph , auto indicator with digital clock)
2. Why the ABS option is not functioning even after replacing the unit.?
3. Can this be happen after a battery is connected with wrong polarity. My friend said that this can happen like that. I also have doubt after I have seen the blasted condenser in the instrument panel.
4. Does this damage some part of the ECU of the car?
Pls help me on this. Pls tell me is there is any place to repair this. I am in Kandy.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
prasannaek123
My questions are
rgds.,
8 answers to this question
