Hi all,
Just a quick question.
As you may know "day time runnung lights" is an option for kia 2011.pls let me know if there are places in sri lanka who can fix the same for one that came without.
why would anyone need DRLs in a sunny, mild weather country like SL. They are for countries where sever weather hampers visibility and safe operation of vehicles. I think, not sure, but Volvo first introduced the DRLs for their cars to take the task of turning on the lights away from the driver so as to ensure a passive safety system.
Maybe OP is getting ready for vesak.
maybe trying to fill an empty gap in his life? Got the permit Kia, but got to get the DRLs else no hot meals and blow jobs from the wife?
I know its funny.
But my friend is dying for this and my ideas was to fix this for his existing one if possible
So you are going to fix thoran lights on your friends car? If you wanted to get him in bed you could just take him out for a nice dinner and movie. Brokeback mountain would work.
Ah explains... Friend can't access the net to ask himself... after all he is 'dying' to get DRLs in his Sorento... must be a GOSL MP or a PC member... ;)
If your friend is seriously struggling to get an erection without one, they are probably integrated into the head lights. So you probably need some new head lights with them on for starters and then figure out what else is missing from the circuit. If the manufacturer used the same wiring loom its likely all you need is to fix the connectors which are already there and possibly the relays that make the system work. I am not familiar with the specific model so to be honest this is a stab in the dark.
People in this country used to die from suicide bombs and continue to die because of floods and other natural disasters. Yet OPs friend is dying because he doesn't have daytime running lights on his permit sportage. Ane paww. Lets help this underprivileged man
Edited by jdnet
you know if your friend is DYING because he doesn't have DRL's. you do know that you can fix aftermarket daytime running lights right?
and why didnt your wierdo friend asked this question himself?? he's in ICU or something?? seriously -__-
I know its funny.
I altogh introduced as a safety feature itoght that DRLs where just for looks in sri lanka
now I know it even save lives
scales of interests and tastes are different from person to person....
So i won't comment about the likes and dislikes of the OP..
As per answering the question...
Yes you can fit daytime running lights...
Two options...
1-buy the OEM Headlights for the later model, so it would be easy swap, same wiring harness can be used, so you've just to plug the socket.eventhough if plug is missing in your one, wiring is an easy task.mind you it'll set off some bucks .
2-you can fix locally sourced set or one imported throug E bay.it won't be a such huge task.
And as a footnote, it won't give much of a use in view of safety, but will add some cosmetics to the car.
Because lot of fuss about safety here,
Yes, it will not help you in sri lankan conditions.but if it's capable of preventing a single collision, i don't have an argument.
Two options...
Cool .... chan 5. this is good news
OP's friend can look good while dying... :)
As pihatu lights... ;) I was asked if the Alfa had them when I put an ad... didn't know what hell thy were till recently... :)
Look at you making dick jokes and all... so proud of you!
Tell your friend running with DRLs increases fuel consumption (it actually does). Then he will be in a real dilemma.......die of wanting to fix DRLs, or die of increased fuel consumption!
Members,
I went through all posts I find every one gives negative reply's. Except for one member.
If he member wants to make his vehicle to have day driving lights, when he on the ignition switch to light.
Then it can be fitted with very low cost but not the original like the manufacture fit, Available in Sri Lanka is the LED lights normal Illumination type.
It is available in 5 meter roles at 600.00 to 750.00 Rupees at 1st cross street Pettah. Only to wire same they are 12 volts DC.
DRAW OF BOTH WILL BE UNDER 1 AMP NOT NECESSARY TO FIX A SEPARATE RELAY CAN WIRE TO SAME IGNITION SWITCH.
I will inform the place for him to go and buy the required LED lights of what is available in 3 to 4 colors he can select color as he likes.
There will not be a extra fuel cost due to very little draw of current. I have them used for last 6 months or more.
Fitting is nothing DIY. They are water proof out door LED lights, comes with back gum tape for pasting on round the head lights or on the light cover.
I have fitted them to my side mirrors and under the grill, so that they will come on when the Heat light switch is operated.
Have one small set on the side mirrors, amber color for them to operate when the signal lights are on.
I used recently illuminate the STAR which was on the Bambalapitiya ST MARY'S CHURCH for Christmas feast.
Every night it was on for more than 15 days with a small 12 volts battery.There were 35 meters of LED bulbs was used. Very little draw of current.
Edited by Sylvi
  • Like 3
Members,
Tks Sylvi
DVT,
They are simply illumination lights not X mes lights, I will send you how they will look when it is illuminated.
I f you want any help to fix them please contact me I will do free of charge.
DVT,
Excellent.Very kind of you.
Pls share a photo if you can
This KIA, I'm afraid, is going to end up looking like a riced up Leyland bus.
