Guys,
i own a 2003 model Honda Fit Aria sedan. Today morning when i popped its hood i noticed a sort of hissing sound coming from the engine bay. couldn't exactly locate where it comes from but sounded like its from intake manifold area ( i am not 100% sure though). More over when i step on gas the hissing increases and it give sort of a sound comes from a blow off valve. couldn't inspect the car further that time since i was rushed for some work. just got back home and planing to get it checked tomorrow morning.
what this hissing sound is likely to be?
could it be a leak from the gasket ?
your inputs are highly appreciated .
Cheers!
Snakes? :speechless-smiley-006:
:) was going to say that. Just make sure there are no snakes in there!
ok jokes apart, Teerex for a start I would suggest just checking if any of the clapms and clips of the air intake have come undone.
Edited by HardHat
you guys mean something like this :speechless-smiley-003: came across that photo while searching for my issue in another Honda forum :)
post-55089-0-28185200-1361751461_thumb.j
Thanks buddy. but it sounded more like it comes under the top engine cover. anyway i will double check again in the morning and update you
Yuk, well hissing days are over for that reptile I guess.
if the hissing sound is from the tappet cover that could be a bit bad news. Remove the engine oil dipstik and race the engine. Remove the engine oil cap and do the same. If there is a spray of oil from either place then that could be signs of a compression leak.
