Chaturathi Posted March 14, 2013 Posted March 14, 2013 Hi, in my honda city (GD 08- Fit area) shows the check engine light on rainy days. i diagnosed the matter & it shows as O2 sensor. 2 years back also i replaced the O2 sensor from ST****D M***RS. Can some help me with this issue. 1.What are the possibilities to happen this on rainy days ? 2.Should i replace this again ? Quote
The Don Posted March 14, 2013 Posted March 14, 2013 Hi, in my honda city (GD 08- Fit area) shows the check engine light on rainy days. i diagnosed the matter & it shows as O2 sensor. 2 years back also i replaced the O2 sensor from ST****D M***RS. Can some help me with this issue.1.What are the possibilities to happen this on rainy days ? 2.Should i replace this again ? I wonder if this is due to condensation in the connectors. Personally I would use some contact cleaner on the wire connector from the o2 sensor and check if its properly sealed. Quote
Rumesh88 Posted March 15, 2013 Posted March 15, 2013 Does the CEL appear within first 500m from a cold start on a rainy day? Was the problem similar when you changed O2 sensor last time? Also what is the Lambda value in your Eco test for the past few years (A figure like 1.02, 1.00 0.95 etc)? Although the Lambda value tested in Eco test is not a clear indication it may give some idea. 1 Quote
Chaturathi Posted March 15, 2013 Author Posted March 15, 2013 yes , the problem is similar to the last time when the O2 sensor was bad. This started happening on rainy days ( within 5 minutes after rain starts) & becomes normal after the rain. But last week on my way to Colombo from Southern high way faced a heavy heavy rain. then the check engine appears & i thought it 'll be ok after the rain. but after 10 days even its still there. After that i did nearly 200 km.Any way i have to replace this for the 2nd time. But how can i know why this is happening ? is this due to bad cat. converter ? but this sensor is before the Cat. converter.(1st sensor) Quote
The Don Posted March 15, 2013 Posted March 15, 2013 yes , the problem is similar to the last time when the O2 sensor was bad. This started happening on rainy days ( within 5 minutes after rain starts) & becomes normal after the rain. But last week on my way to Colombo from Southern high way faced a heavy heavy rain. then the check engine appears & i thought it 'll be ok after the rain. but after 10 days even its still there. After that i did nearly 200 km.Any way i have to replace this for the 2nd time. But how can i know why this is happening ? is this due to bad cat. converter ? but this sensor is before the Cat. converter.(1st sensor) Try what I suggested first. It could still be a faulty sensor but you should clean the contacts when the check the wires to see if they are still electronically shielded and not damaged. A short circuit on the wires of the sensor can cause a fault reading on the ECU. Quote
Rumesh88 Posted March 16, 2013 Posted March 16, 2013 (edited) According to what you have said above the chances are more for an issue with the sensor wiring as Don says. It is a bit unlikely for an original O2 sensor fail due to wear in two years unless you run for something like 100,000 km but it is still a possibility. However, a fault with wiring would not cause an O2 sensor itself to fail prematurely. Edited March 16, 2013 by Rumesh88 Quote
Sylvi Posted March 16, 2013 Posted March 16, 2013 Chaturathi, Read the following web articles you will get some idea of engine light. http://www.engine-light-help.com/check-engine-light-circuit-testing.html Sylvi Wijesinghe. Quote
Chaturathi Posted April 10, 2013 Author Posted April 10, 2013 Hi, finally i replaced the lambda sensor ( a used one) & now fuel consumption is bit low ( city 7 kmpl / outstation 14 kmpl) . before it was 10 in the city & 16 outstation. These are the lambda readings after replacing the sensor. Sensor 01 - 0.72 v (replaced one) Sensor 02 - 0.84 v can this happen due to voltage difference ? Quote
The Don Posted April 10, 2013 Posted April 10, 2013 Hi, finally i replaced the lambda sensor ( a used one) & now fuel consumption is bit low ( city 7 kmpl / outstation 14 kmpl) . before it was 10 in the city & 16 outstation. These are the lambda readings after replacing the sensor.Sensor 01 - 0.72 v (replaced one) Sensor 02 - 0.84 v can this happen due to voltage difference ? Your ECU might take a little bit of time to learn off the new lambda sensor. Personally I don't think you should ever replace a lambda sensor with a used item (they are like spark plugs). They have a finite life time and its possible the one you replaced is in worst shape than the original unit. Quote
Rohnd Posted April 13, 2013 Posted April 13, 2013 Hi, finally i replaced the lambda sensor ( a used one) & now fuel consumption is bit low ( city 7 kmpl / outstation 14 kmpl) . before it was 10 in the city & 16 outstation. These are the lambda readings after replacing the sensor.Sensor 01 - 0.72 v (replaced one) Sensor 02 - 0.84 v can this happen due to voltage difference ? The Oxygen Sensor can be regarded as a previentive maintenance item in most cases,should be replaced with genuine ones to match the ECM formula. The replacements and used ones are not recommended if you expect the 100% performance. 1 Quote
