Diy Honda Crv Valve Cover Gasket Replacement
blkr6
  On 7/7/2013 at 4:47 AM, The Don said:
Blkr6, what might also be useful is if you list the parts and also tools required for the job as well, just so that other DIY mechanics don't start things they can't finish.
Thank you for the tip Don.
Items you need: Valve Cover Gasket set, RTV sealant, brake/carb cleaner (or any solvent), paper towels or rags, 10mm, 14mm Sockets with a ratchet, screw driver or pry bar, pliers to remove vac hose clamps,
Things that could go wrong:
if the spark plug wires are very old there is a chance that you could damage and needs replacement, check the condition of the PCV valve and the timing Belt, if your engine has a valve noise its a good time to adjust the valves as well,
  On 7/7/2013 at 4:44 PM, c1nder said:
nice vid! What gloves do u use btw and where'd u get them?
Thank you! i live in the states and i bought it from a parts store. i cant remember the brand but i go with the blue once since they are little stronger.
