Honda Fit Vs Toyota Vitz
3 answers to this question
Fit is fun to drive Vitz is quite numb :) for the most part both will run and run well as long as you take care of it...
Fit and Vitz are neither a SUV or a Minivan....what exactly are your requirements ?
Beauty and passenger space
Beauty is a matter of personal taste/opinion...I guess both look okay butpersonally I like the Fit's lines a bit better...Vitz looks a bit more cheap and plasticy inside. Fit seems to have a bit more space than the Vitz too....especially in the back...although the Vitz has a slightly higher rear seat so although space is a bit less you still sit in a non -cramped way....
Still Vitz/Fit does not offer same room/space as a Noah or a SUV....
maybe you need to consider what you will be using the car for and where you will be driving it....and then figure out if you need a hatchback, a MPV or a SUV..needless to say, beyond just moving from one place to another, all three categories are meant for 3 different categories of use ?
