​ Welcome Forum Guest! 👋 ​
Tune 4G15 Carburetor
On 9/2/2016 at 5:02 PM, Gihanmj said:
Hi all,,
i have CB 1 1995 model car. it is also consist with bothal type carb. when overtaking or driving on a mountain way it is knocking. this is occur when the accelerator pushing a certain depth. power is low. i feel that. one mechanic told me to replace distributor. but i m not satisfying with this answer, if anyone knows or feel the problem please help me to solve it :)
I assume that by "knocking" you meant a hesitation or a "miss" in the engine not the pinging (or kara kara noise) sound you get when your ignition timing is too advanced. Please correct me if my assumption is wrong.
First get the all spark plugs, plug wires, air cleaner (replaced if necessary) and all the vacuum lines checked. If possible get the ignition timing checked too. If you narrow the problem down to a fuel starvation issue from the carb then find someone who is really familiar with dismantling and reassembling a "bothal carb" . If you carefully read the previous posts in this thread you will understand why. To me it looks like either your fuel level inside the carb is low or the carb piston gets stuck at some position. How about your last Eco readings at idle and 2500 RPM?
  • 1 year later...
  • Replies 55
  • Views 71.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Hi guys, I have Mitsubishi C62A (known as ASP Model 1991). It has 4G15 engine and very powerful. But I'm not happy with the fuel efficiency of this car. And there is a black smoke as well. I just sur
  • This i highly recommend through my experience.. I was experiencing some what similar issues with my carb and non of the cleaning and using non genuine carb repair kits did work. Ultimately got myself
  • <blockquote class="ipsBlockquote" data-author="kusalk" data-cid="272881" data-time="1424708011">Dear Rumesh, <p>I'mm having a Lancer CK2 with 4g15 engine. But the carb of it gives a lot o
I have a Lancer CB2 1995 which also has an issue with the carb
The fuel comsumption is very high and only does like 7km/L
The carb had never been tuned or serviced
Current mileage is around 160,000 km
Any reasonable and a qualified mechanic whom i can consult ?
Talk to Mr. Dhammika in cotta road
0112694223
  • 2 years later...
  • 2 months later...
Hello,
Can someone please recommend a mechanic for tuning a 1988 Ford Laser?, issue is fuel consumption is high.
Thanks and best regards
Randy
