Car Is Not Speedup When Accelerating + Bad Smell
where is Rumesh88? i think he was online yesterday,
Irosh, try to PM him and invite to join to this thread
Oops! I had a problem with my shared resources while I was on the move and only one lap top in the car shared with family and too bad I had limited access to it). Post edited below now that I have everything to myself.
Irosh
1. before you start the engine after being parked overnight, press the brake pedal hard a few times. Pedal stroke (travel) should be the same each time. If not you have a probable issue with the master pump like washers. Unlikely in your case for brakes are operating so this step is not required.
2. With the pedal depressed start the engine, the pedal should go down slightly. This is the normal operation. If not you have a issue with booster most likely a vacuum leak or the vacuum not reaching the booster. When you press the pedal the engine idle speed should remain stable. According your previous posts I suspect a vacuum leak. If so you need to attend to it and then set your air/fuel adjustment again.
3. Release the pedal and allow the engine to run idle for a minute of so and then depress the pedal fully and switch off the engine while keeping the pedal depressed with constant force (better do it barefoot). Now hold it. The pedal stroke should remain at the same position (meaning it should not come up)for about 30 seconds. if the pedal comes up (meaning you need more force keep it pressed) immediately you have a leak in the booster or its non-return valve.
4. Release the pedal and start the engine again for about 2 min and switch off. The press the pedal consecutively for about five times. During first few strokes the pedal should come up progressively each time. This again confirms if the booster is airtight. If it comes up on the first stroke you have a leaky booster.
Try this simple test and post your results.
Edited by Rumesh88
