I have a diesel corolla 110 manual one. This evening when returning home I stopped at a gas station and when pulling to the road I noticed that the temp gauge had suddenly moved above the 3/4 mark. It was fine (in the 1/2 mark) about 2 mins before.
I thought the needle was acting up but pulled over turned off the engine and turned the key back to ON, then the needle came to the 1/2 mark, but when started, it moved from 1/2 to 3/4 within about 20 seconds !. I drove again for few seconds and the gauge kept rising so I stopped and checked the fans. AC was off and both the fans were off although the temp was high.
When the engine is off and the key is in ON the needle sits around the half mark and it went up only when the engine is started,
Then I turned on the AC and then the temp slowly became normal. Then I started driving again but the temp kept rising when the AC cuts out. But the whole drama was over in another 10 mins and everything is back to normal now. Now the temp is normal and the fans come on usual way. After that I noticed the radiator top tank was almost empty although the plastic tank has coolant in it (but the temp was fine although the radiator was missing close to 1L of coolant). When the temp was high I noticed a bit of coolant where the top tank meets the radiator core and there was a bit of smoke coming from the tube that goes into the plastic tank from the radiator - is it normal ?
So my questions are could this be due to a bad gauge or an issue with the fans. - I mean will the temp go up that fast (1/2 to 3/4) in 20 seconds if the fans are not running ?
My trusty old electrician is gone so I'm kinda hesitant to show this to an unknown guy as the issue is gone now. Could you recommend a good place around Nugegoda area ?
Lastly any other symptoms of overheating engines if you don't / can't trust the temp guage ?
Is there an alternative to the Maruti 800? A friend of mine is looking for an extremely cheap to run and fix car for around 1.5M. While I do advocate old Japanese cars in that budget - if his need is basic A-B motoring at the lowest possible cost - maintenance wise and with fuel - is there any other option that I am forgetting?
Does anyone know how exactly this is supposed to work? They haven’t really started brand new imports again right?
Pricing seems relatively fine in the grand scheme of things, given how 10/15 year old cars are still pretty expensive in our market
A guy advertises a mileage blocker on the quick site saying that his device blocks the vehicle mileage from changing on the odometer. Is it legal to advertise stuff like this?
Bought a 2007 (Reg 2011) Vitz SCP90 (Mileage 180K+) for the family (will be used by my father). Seems to be in good condition but had some new owner repairs/replaces done to have a free mind.
Amila G
Hi guys,
7 answers to this question
