Wagon (Nissan, Toyota)
19 hours ago, iRage said:
Uhh....the 1st Gen Pajero ended in 1991....are you referring to the 1st Gen L040 series Pajero๏ปฟ or the 2nd Gen V20 series Pajero ?
It would be a good option if you can find a decent unit. Being an old diesel engine there are issues that come along with that you need to make sure has been attended to or plan to attend to it. If you are actually referring to the 2nd gen, the vacuum based 4WD system needs to be checked properly too.
Also, you better check if the body and engine are legit and not swapped :)
Thanks need to check. I was referring to the 1st Gen which is called Palathsabha here...
On 3/7/2019 at 4:22 PM, iRage said:
Aha...that is the 1st gen. But decent ones are pretty hard to find though...especially ones that have not had the body messed up (swapped).
True let's see what comes up on the classfields ?
