civicferio Posted March 7, 2014 Posted March 7, 2014 Hi guys, I'm posting this onbehalf of my friend because He is totally wrecked with the engine trouble he has in EK3 Vi 1996. Here is the Issue, It started with a delay in starting and when engine gets started the RPM ran up to 2000 even when the engine is in working temp. When he start moving under this condition ignition noise came in. Now the car won’t start unless he keep on starting for 2-3 times. he has done following thing but the problem is still there. Changed the throttle body (in intention of changing the IACV) Changed the Petrol filter and cleaned injectors (Helped to keep him away from the issue for about 3 weeks) Changed the Ignition coil Changed plugs Please help him to overcome this unidentified issue… Thanks Quote
The Don Posted March 7, 2014 Posted March 7, 2014 Does the car burn oil? When he replaced the spark plugs, what was the condition (colour) of the previous plugs? Quote
civicferio Posted March 7, 2014 Author Posted March 7, 2014 Does the car burn oil? When he replaced the spark plugs, what was the condition (colour) of the previous plugs? Car doesn't burn Oil. Spark replaced yesterday. CAM sensor? What is the state of the T Belt? there is no any MIL codes. done 80k after changing T-belts Thanks all. Quote
VVTi Posted March 7, 2014 Posted March 7, 2014 (edited) Car doesn't burn Oil. Spark replaced yesterday. there is no any MIL codes. done 80k after changing T-belts Thanks all. Sometimes some faults do not throw errors. Check the numbers during a live scan. 80K after a T belt change means its time to change, especially in SL. It could be some notches are broken in the belt and a few teeth have jumped. Edited March 7, 2014 by VVTi Quote
maheshw Posted March 7, 2014 Posted March 7, 2014 has he done anything in petrol pump? maual or auto tranny ? Quote
civicferio Posted March 7, 2014 Author Posted March 7, 2014 (edited) has he done anything in petrol pump? maual or auto tranny ? Yes. checked the petrol pump and all okay. fuel pressure also okay. changed fuel filter a month ago. it is a multimatic. ( CVT) Thanks Edited March 7, 2014 by civicferio Quote
Rumesh88 Posted March 7, 2014 Posted March 7, 2014 Just need a few clarifications. How about the cold start? Is it the same (Not the high revs but repeated starting attempts)? When changing the throttle body in addition did they change IAC valve, fast idle thermo valve (valve located at the bottom side of the throttle), MAP sensor etc along with it? Also once started is it possible to drive the car smoothly (ignoring the high revs of course)? Quote
civicferio Posted March 7, 2014 Author Posted March 7, 2014 Just need a few clarifications. How about the cold start? Is it the same (Not the high revs but repeated starting attempts)? When changing the throttle body in addition did they change IAC valve, fast idle thermo valve (valve located at the bottom side of the throttle), MAP sensor etc along with it? Also once started is it possible to drive the car smoothly (ignoring the high revs of course)? Cold start is okay ( in the morning ). after the normal start it drives smoothly. but when the issue happens ignition sound comes and the car is not smooth. IAC and MAP sensor changed along with the TB. Quote
Rumesh88 Posted March 7, 2014 Posted March 7, 2014 Cold start is okay ( in the morning ). after the normal start it drives smoothly. but when the issue happens ignition sound comes and the car is not smooth.IAC and MAP sensor changed along with the TB. OK. If you remove the air duct from the throttle body you would notice two ports before the throttle flap on the throttle body - one towards IAC valve and another one located below the first port. With the engine warmed up and in idle, you should not feel any vacuum on the lower port. One can just keep a finger on the port to detect the vacuum. It helps to rev up and down couple of times while checking to see if it makes any difference for the problem is intermittent. If there is vacuum on the lower port when the engine is hot then you have problem with the thermo valve. Make sure the coolant lines connected to the thermo valve are OK and the valve gets warmed up along with the engine block. You can feel the valve to observe it warming up after a cold start. If this is OK then you are likely to have a problem with timing as others have pointed out above. Quote
civicferio Posted March 10, 2014 Author Posted March 10, 2014 Hi, He has changed ECT sensor according to a mechanic in Kandy. Now it seems Okay. He will monitor some more days. according to the mechanic this is a common issue for Ek3 in USA. Thanks Quote
Sssuneth Posted April 28, 2014 Posted April 28, 2014 I think am experiencing the same issue. Morning start never fails but after drive and try to start ONLY some times it takes a while to start. leaving the car for few minutes will do the trick. Could it be ECT sensor ? CIVIC Ferio - EK3 (ML)- Normal Auto - 1997 Quote
Sssuneth Posted April 28, 2014 Posted April 28, 2014 May I also know where I can buy this ECT Sensor from? (Other than Stafford Motors ) I rang TECK motors ,I v been asked remove it and bring.. Is there a model number or any sort of number(temperature) that I need to match.?? Quote
Chanaka Gunawardena Posted April 28, 2014 Posted April 28, 2014 I think am experiencing the same issue. Morning start never fails but after drive and try to start ONLY some times it takes a while to start.leaving the car for few minutes will do the trick. Could it be ECT sensor ? CIVIC Ferio - EK3 (ML)- Normal Auto - 1997 Check the starter motor solonoide and starter motor condition before moving into sensor replacement. Quote
Strikeee Posted April 29, 2014 Posted April 29, 2014 I too facing the same issue from Sunday. car doesnt start at 1st time... this normally happens when starting after a quite long break( like 3hrs +) only occurs during the 1st attempt. Today, I check plugs, battery and air filter... and found out that there are some kind of a liquid inside the throttle body. Is this normal?? if not what can be the issue??? Il try to upload images of my throttle body Engine is D15Z4 ,EK3 exi Quote
civicferio Posted May 5, 2014 Author Posted May 5, 2014 Hi, One of his mechanic in Kandy sold it to him. according to him it was removed from an old engine. thanks. Quote
