Recently i did a carburetor cleanup using carb cleaner and changing the JETs and gaskets. I did the same 2 years back and after fitting the carb back the engine ran fine. But this time after fixing the carb the idle seem to run smooth. But when i pickup the car in 1st gear the car stumbles a bit (hesitate) and then returns to the rpm which it should according the throttle position. This only happens at certain angle in the throttle movement as i have notice. But pushing Gas pedal beyond that angle accelerate the engine just fine. What could be the reasons to have such symptoms ? I checked the accelerator pump which seem the work as expected.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
GAPAUTO
Hi Guys,
Engine Model : Mitsubishi 4G12
GAP.
8 answers to this question
