Dear All,
My problem is about power shutters and the vehicle is toyota allion. Problem is left side shutter are not working when it operate from the driving seat switch pannel(center location) but it works without any issue when it operate from the relevant door switch itself. can this be because of a damaged fuse? Appreciate your experts comments
5 answers to this question
This was due to the bad contacts in Main panel. Open and cleaning might sort out the fault. Bt do not by pass the switches. it can blown your fuses.
Thanks maheshw & asrock. I ckecked the panel through a mechanic and his advice is to replace the panel completly. dont know how much will it cost. Does anybody knows a good place to check this one ?
Replacing the panel is good advice in my opinion. Dismantling and messing around with the panel may only be a short term solution.
Its not like allion parts are a rarity.
