Is there a good place for car dvd set of good quality to be purchesd and fix
You will find more info with a search. But to start with i've been going to P#TCO for my car audio stuff and they've been doing a good job for me. Few tips if we haven't discuss earlier on DVD systems;
1. When you are fixing a DVD head-unit make you that you by-pass the parking break. Otherwise you wont be able to play DVD or Video on USB, etc.. until your parking break (hand break) is enabled.
2. Also try to search for a DVD unit with apple car play bcos it will be handy when you have an Iphone. You might even consider ones with GPS too if you are not using Car play.
3. If your car already came with a premium sound system (Eg Bose sound system) make sure the new headunit is compatible with that. BCos when you fix a 3rd party headunit with existing amp the speakers are giving a hissing noise even your volume is all the way down to 0. So make sure you check on this.
4. A minor point fixing DVD set is many buy reverse camera along with it. But make sure it is fixed on a good place without having it on a odd place which screw the look of the can and make sure the guidelines are properly set. Sometimes depending on the place you fix the reverse camera the guidelines cannot be set properly. so best thing is before fixing permanently use double tape or something and check the guidelines first.
5. If you car already came with voice activation / Phone paring feature ask the technician to try using the existing mic. BCos the mics comes with some of the head units the finish is not good. If the existing car mic cannot be used try to fix in a discrete place. Otherwise it will look a little odd.
6. Make sure all the steering controls are usable with the headunit and functioning properly. (Including phone controls.)
7. Make sure all the antennas working properly (including additional ones depending on the features like HD radio antenna, GPS antenna, etc..)
Will post if i get more points. Hope these tips might help for now,
KMeeg.
