C Perera Posted October 10, 2014 Share Posted October 10, 2014 Dear Friends, I have a N16 Auto Car. Now there is a sound "Hmmmmmmm" from Razors ( i think so). Do i have to replace those? If so, what it will be the cost ? Quote Link to comment Share on other sites More sharing options...
maheshw Posted October 10, 2014 Share Posted October 10, 2014 with your informations its bit diffuclt any one to comment whats exactly happening? Describe when it happening? as you guess from where it's coming? if it's coming from engine is it while A\C on or off? Quote Link to comment Share on other sites More sharing options...
The Don Posted October 10, 2014 Share Posted October 10, 2014 On 10/10/2014 at 2:08 PM, C Perera said: Dear Friends, I have a N16 Auto Car. Now there is a sound "Hmmmmmmm" from Razors ( i think so). Do i have to replace those? If so, what it will be the cost ? Its easy to figure out if its the bearings. If its from the engine mechanics use a scope like device to listen to the hum and pin point where its coming from. Quote Link to comment Share on other sites More sharing options...
Muditha420 Posted October 10, 2014 Share Posted October 10, 2014 you might wanna do a bit more explaining on this matter.... if its the bearings can be done for about 3k Quote Link to comment Share on other sites More sharing options...
bycap Posted October 11, 2014 Share Posted October 11, 2014 On 10/10/2014 at 2:08 PM, C Perera said: Dear Friends, I have a N16 Auto Car. Now there is a sound "Hmmmmmmm" from Razors ( i think so). Do i have to replace those? If so, what it will be the cost ? If the sound comes from wheels its possibly the hub razors. you can check this easily. Jack up the car, rotate the wheels. If they do not rotate smoothly possibly hub razors are gone. Modern hub razors come as a compact set with 4/5 screws. . 1 Quote Link to comment Share on other sites More sharing options...
simpleone Posted October 13, 2014 Share Posted October 13, 2014 I did a hub razor replacement 2 years ago. It was about Rs.2000 per wheel. If the intensity of humm varies with the speed, this could be a probable hub case. Quote Link to comment Share on other sites More sharing options...
harshansenadhir Posted October 14, 2014 Share Posted October 14, 2014 it could be as simple as badly worn out tire or tires. best is to isolate which tire has the noise and check with a different tire (i.e spare wheel ) to see whethe the noise disappears. Then you can get into other diagnosis such as checking hub bearings. Most probably this should be from rear wheels. Quote Link to comment Share on other sites More sharing options...
